Problem with bypass
If your bypass is not working, I would suggest that you review the instructions and check your work. If done correctly, it WILL work. If you have not reset your unit since installing the bypass, try pressing the small reset button on the front lower left of the unit. Based on your description above, it sounds like the light green parking brake wire is not grounded properly. Check it first.
