elansinger Posted January 19, 2007 Report Share Posted January 19, 2007 I just replaced my factory speakers with Alpine 6.5 and 4 inch along with an Alpine 100WX4 amp. I turn down the gown quite a bit but still have an audible background hissing that is very very annoying. Anyone know what I can do about this? Quote Link to post Share on other sites
action Posted January 19, 2007 Report Share Posted January 19, 2007 Is it possible that there is a factory amp? So you are amplifying and amplified signal? Quote Link to post Share on other sites
tillithz Posted January 19, 2007 Report Share Posted January 19, 2007 sounds like engine noise? alternator whine ? check grounding points, should have as few as possible, make sure gauge is same size for both power and ground. make sure amp isnt digging into the body of the car on one of the corners, clean your distributor cap out. and maybe respond back. Quote Link to post Share on other sites
tillithz Posted January 19, 2007 Report Share Posted January 19, 2007 btw what kind of car is that? Quote Link to post Share on other sites
cntrylvr79 Posted January 19, 2007 Report Share Posted January 19, 2007 btw what kind of car is that? A shot in the dark here but I'm going to guess one with 4 wheels, a motor, and a couple of doors... Quote Link to post Share on other sites
tillithz Posted January 19, 2007 Report Share Posted January 19, 2007 not a side car? damn, im wrong again Quote Link to post Share on other sites
elansinger Posted January 22, 2007 Author Report Share Posted January 22, 2007 No factory amp. It's a 2001 M3. Will try your suggestions tillithz and get back to you. Thanks. Any role for a noise suppressor? Quote Link to post Share on other sites
tillithz Posted January 22, 2007 Report Share Posted January 22, 2007 a noise suppressor is just a band aid for the real problem, and not only will it suppress the hiss, but the entire sound spectrum which you probably dont want. Quote Link to post Share on other sites
elansinger Posted January 22, 2007 Author Report Share Posted January 22, 2007 OK thanks for the info. Quote Link to post Share on other sites
Inspector_Gadget Posted January 25, 2007 Report Share Posted January 25, 2007 tillithz, do you NOT have any hiss? I removed my factory setup (head unit, all speakers and sub) and used an external amp. All professionally installed. All new wires, no factory re-use. I did retain my factory rear DVD setup that plays both audio and video to the Z1. I get hiss all the time. I'm betting this is the cause of my hiss... I have an appointment Saturday to have the system rechecked and to add the iPod controller. Any thoughts as to what to have the installer pay close attention too? This will be his 3rd attempt at removing hiss. I think he put a filter on before but it didn't help very much, if at all. Thanks! Quote Link to post Share on other sites
