RacerX930BT Posted January 17, 2012 Report Share Posted January 17, 2012 Everything works fine Bluetooth phone calls and all else except if I wanna play the music on my iPhone thru Bluetooth audio. I have to take off my iPhone case and plug in to listen to music on my iPhone. Which is a hassle each time. More than that everything should work regardless Quote Link to post Share on other sites
RacerX930BT Posted January 17, 2012 Author Report Share Posted January 17, 2012 It syncs up and it plays the audio. I can see the track scrolling through. Just can't hear it. Quote Link to post Share on other sites
ThumperPup Posted January 18, 2012 Report Share Posted January 18, 2012 check the volum on the iphone make sure you Ipod volum is not turned all the way down sometimes id say 8 out of every 10 times i synch up it turns the Volum down all the way on the ipod but only for BT audio Quote Link to post Share on other sites
RacerX930BT Posted January 18, 2012 Author Report Share Posted January 18, 2012 i noticed this earlier this afternoon and that WAS the issue... gotta say its pretty awesome that even tho i figured it out someone knew the issue... thanks man thats pretty hilarious! Quote Link to post Share on other sites
ThumperPup Posted January 19, 2012 Report Share Posted January 19, 2012 its really annoying i stopped using the BT because of that and now only use the Ipod when i need it to be charged and when not charging or plugged in i use the SD for the Audio i am really dis pointed with the way this is i think pioneer needs to figure this problem out and fix it Quote Link to post Share on other sites
Prerunner84 Posted March 1, 2012 Report Share Posted March 1, 2012 I'm having the same problem did u ever get it worked out? Quote Link to post Share on other sites
