Maguinee Posted February 12, 2012 Report Share Posted February 12, 2012 I apologize if this has been covered before. I have done several searches and have not found anything in forums that address this so I'm posting a new question. I have an iPhone 4 with an "incase" two piece phone case. I have the Z130BT with the Pioneer Cable and the cable does not fit through the charging port on the case. Currently I have to remove the lower half of the case to hook the cable up. Not the worst thing in the world but would prefer not to have to. I could drill out the slot on the case but my case is old and I'm looking to replace it anyways. I could also trim down the plastic on the cable's connector but really don't want to to do that with a $60 cable. My luck I'll ruin the cable. Does anyone have a case that is compatible with that cable? Quote Link to post Share on other sites
RonS Posted February 12, 2012 Report Share Posted February 12, 2012 Had that problem with my iTouch case. I just used a hand file and enlarged the hole for the connector. Don't remember what brand the case was - just a cheap case. Quote Link to post Share on other sites
Maguinee Posted February 13, 2012 Author Report Share Posted February 13, 2012 RonS Thanks! Since I care far less about my case than the cable I decided to take your advice and try to file my case out. I used a round rattail file and it worked like charm. I am still looking for other case options as I want to replace my case anyways. At this point if nobody knows of another option then I will buy another "incase" and reuse the bottom portion that I filed out. I appreiate your response Ron! Maguinee Quote Link to post Share on other sites
zx6rrdan Posted February 13, 2012 Report Share Posted February 13, 2012 I've got a Belkin Folio leather and it's no problem with the cable Quote Link to post Share on other sites
Maguinee Posted February 13, 2012 Author Report Share Posted February 13, 2012 Thanks zx6rrdan I'll have to take a look at that one. Not sure the wallet style is what I'm looking for but I'm open to looking at anything. maguinee Quote Link to post Share on other sites
Raider0914 Posted February 15, 2012 Report Share Posted February 15, 2012 Have both the incipio double cover and the otterbox commuter case. Both work well with the pioneer cable. Btw i have iphone 4s. Quote Link to post Share on other sites
dentauthority Posted February 19, 2012 Report Share Posted February 19, 2012 Currently using this with the iPhone 4S & the Life Proof case: http://www.amazon.com/RadTech-13-860-ProCable-Shortz-Extender/dp/B0072XH47U Quote Link to post Share on other sites
Maguinee Posted February 19, 2012 Author Report Share Posted February 19, 2012 Thanks for the additional info. Raider - I took a look at the cases and right now the front runner is the Otterbox. Looking more at the defender than commuter mainly because of the camo option. Any reason that you are aware of that I shouldn't do that? Dentauthority - Thanks to you as well. I have ordered one of those adapters and am looking forward to it. I've never seen anything like that. Maguinee Quote Link to post Share on other sites
Zrullac Posted February 21, 2012 Report Share Posted February 21, 2012 I use an Otterbox Defender case for my Iphone 4. Works very well with the Pioneer cable. No issues whatsoever. I apologize if this has been covered before. I have done several searches and have not found anything in forums that address this so I'm posting a new question. I have an iPhone 4 with an "incase" two piece phone case. I have the Z130BT with the Pioneer Cable and the cable does not fit through the charging port on the case. Currently I have to remove the lower half of the case to hook the cable up. Not the worst thing in the world but would prefer not to have to. I could drill out the slot on the case but my case is old and I'm looking to replace it anyways. I could also trim down the plastic on the cable's connector but really don't want to to do that with a $60 cable. My luck I'll ruin the cable. Does anyone have a case that is compatible with that cable? Quote Link to post Share on other sites
Raider0914 Posted February 21, 2012 Report Share Posted February 21, 2012 I just didn't like the bulk of the defender. The commuter is a little slimmer as it doesnt have the built in screen protector. Quote Link to post Share on other sites
