killakross Posted March 4, 2012 Report Share Posted March 4, 2012 i just purchased my avic and i am having troubles getting the gps to read were i am at?i believe i have the vss wire hooked up right,the car is a 02 vw jetta tdi, every feature works,disc,ipod,aux, i have reset my current location but the gps does move when i move, when i am in nav mode with cd in, i hit menu,settings,hardware info.,3d calibration, the distance doesnt change stays at 0.00 speed pulse is at 268,it goes up when i drive? learning status says sensor initialing......the bottom half of the screen speed,distance right turn anfd left turn never change. always empty.., when i hit back, and go to connection status speed pulse is at 0 unless im excellerating, gps atenna says ok wityh a green icon thren grey diagnal icons,,idk if that means full service or none... i have my set up by passed so p brake is onl...illumination says off...back single says low... i dont have the reverse wire hooked up and not 100 percent certain i have vss hooked up right,, any suggestions or tips? Quote Link to post Share on other sites
1loudls Posted May 24, 2012 Report Share Posted May 24, 2012 unhook the VSS wire, reset the unit and see what happens. also, where do you have the GPS antenna located? Quote Link to post Share on other sites
