walton1974 Posted March 10, 2012 Report Share Posted March 10, 2012 Hi - can someone give me some idiot-proof instructions on how to ground the parking break wire please. Which wire do I ground it to? I'm not fussed about watching DVDs whilst on the move, all I want to do is access the Phone and GPS menus when stationery as a minimum. Do I really need to move and ground the mute wire too? Thanks Started new post after subsequent reading and investigation. I think I'm missing wires from my F9110BT. Would be really grateful for any help! http://avic411.com/i...hen-stationary/ Quote Link to post Share on other sites
JasonH Posted March 10, 2012 Report Share Posted March 10, 2012 Ground the parking brake, move and ground the mute wire, done. Quote Link to post Share on other sites
walton1974 Posted March 11, 2012 Author Report Share Posted March 11, 2012 Great thanks - can I ground it to one of the other wires in the loom if so which one? Quote Link to post Share on other sites
VBLUE42 Posted March 11, 2012 Report Share Posted March 11, 2012 If you have to ask this question you should take it to a professional installer. Quote Link to post Share on other sites
walton1974 Posted March 11, 2012 Author Report Share Posted March 11, 2012 Thanks - I am competent enough to do this just wanted to check that I was doing it the right way as there is different advice across the forums. I actually think I have a problem with the wiring supplied with my unit. Maybe you can help me with that... I've got a F9110BT with CAN BUS trying to fit into a 2009 Passat. I'm getting the greyed out menu items, but from what I've read I shouldn't be. I'm getting this when I'm stationery and the brake's engaged. I was hoping the bypass would solve the problem, but having read through posts all weekend and looking at what feels like hundreds of pictures, I think I am missing some wires from the connector from the unit going into the can bus. All the posts i've read talk about a light green brake wire - I haven't got one. There are 3 green wires, one with black stripe but all the same green. So I don't think there is a signal going to the unit telling it the brake is engaged. Any ideas? Quote Link to post Share on other sites
VBLUE42 Posted March 12, 2012 Report Share Posted March 12, 2012 There has to be a Parking Brake wire somewhere on that harness, you just have to find it. And if your using a US unit, your going to have to have a wire in place of the mute wire in order to be able to have a working bypass. And as mentioned above, both wires will need to be grounded. Quote Link to post Share on other sites
