Workmuch Posted May 4, 2012 Report Share Posted May 4, 2012 Hey guys, new member 1st post and awesome forum. Thanks, ton of great info. Got a new 140bt and I'm trying to figure out the best video format & specs for the SD card videos. (and USB HD videos) I have tried h264 mp4, 800x450 (same scaled ratio as all my digital 720p movies) in the following bitrates; 3000k, 2000k, 1500k and 1000k and non have worked (140 says "all skipped, can't play videos"). My test video is only 5 mins. Basically I'm looking for the highest quality that I can convert my current 720p 3000k mp4's to, that will play the best on the 140. Currently using a 4gb SD card, reads fine with pics (wallpapers). Going to wait to go bigger till I figure this out. Thanks in advance for your help. Christian Quote Link to post Share on other sites
zx6rrdan Posted May 4, 2012 Report Share Posted May 4, 2012 h264 640x480 Bitrate must be under 1k for the complete stream try - 800k bit rate for video 128k bit rate for audio file size under 2gb Quote Link to post Share on other sites
JasonH Posted May 4, 2012 Report Share Posted May 4, 2012 The iPod setting in handbrake works well. Quote Link to post Share on other sites
XenuStardust Posted June 13, 2012 Report Share Posted June 13, 2012 Im having a similar issue with my z120 video playback through the SD. it says "all skipped, can't play videos". i've tried .AVI, and .MPEG, and i've done so using handbrake with both settings mentioned above and still no playback. what am i doing wrong? Quote Link to post Share on other sites
naughtyca Posted June 13, 2012 Report Share Posted June 13, 2012 Heres the link for this issue http://avic411.com/index.php?/topic/26312-confirmed-generic-divx-format-for-sd-avi-and-dvd-divx/ Quote Link to post Share on other sites
