rachidfunaki Posted July 10, 2012 Report Share Posted July 10, 2012 I've google'd and searched for a few hours and I can't get to the calibration screen. I think it has something to do with the fact that the screen is so off I can't press the off button after getting to the source screen. I've tried to press and hold the src button to turn the unit off but it doesn't do anything unless the screen is closed. Once it's closed holding the button turns off the light but when I hold the band button it doesn't bring up the menu. Anything else I can do or am I doing something wrong? I appreciate any help I can get from you guys. Hell i'll pay 10 bucks paypal if I can save the 120 dollar repair fee! Quote Link to post Share on other sites
rachidfunaki Posted July 13, 2012 Author Report Share Posted July 13, 2012 10 dollar paypal reward for helpful info! I'm all over caraudioclassifieds.org and i'll pay up Quote Link to post Share on other sites
rachidfunaki Posted July 18, 2012 Author Report Share Posted July 18, 2012 Is there a way to turn the HU off without being able to touch the off button on the screen? With the remote maybe? Quote Link to post Share on other sites
mrchrisbrown Posted October 6, 2012 Report Share Posted October 6, 2012 same problem!! any answer yet? Quote Link to post Share on other sites
tokapaho Posted October 7, 2012 Report Share Posted October 7, 2012 Have you tried this: Adjusting the response positions of the touch panels (Touch Panel Calibration) If you feel that the touch panel keys on the screen deviate from the actual positions that respond to your touch, adjust the response po- sitions of the touch panel. There are two ad- justment methods: 4-point adjustment, in which you touch four corners of the screen; and 16-point adjustment, in which you make fine-adjustments on the entire screen. ! Park your car in a safe place and use this function. Do not operate it while driving. ! Touch the screen gently for adjustment. Forcefully pressing the touch panel may da- mage the touch panel. Do not use a sharp pointed tool such as a ballpoint pen or me- chanical pen. Doing so may damage the screen. ! If the touch panel cannot be adjusted prop- erly, consult your local Pioneer dealer. 1 Turn the unit off. Refer to Basic operations on page 14. 2 Press and hold HOME to start Touch Panel Calibration. The 4-point touch panel adjustment screen ap- pears. When 2-point appears at once, touch both. 3 Touch each of the arrows on the four corners of the screen. # To cancel the adjustment, press and hold HOME. 4 Press HOME to complete 4-point adjust- ment. Data for the adjusted position is saved. # Do not turn off the engine while the data is being saved. 5 Press HOME to proceed to 16-point ad- justment. The 16-point touch panel adjustment screen appears. # To cancel the adjustment, press and hold HOME. 6 Gently touch the center of the + mark displayed on the screen. After you touch all the marks, the data for the adjusted position is saved. # Do not turn off the engine while the data is being saved. 7 Press and hold HOME to complete the adjustment. Just an idea. Quote Link to post Share on other sites
DeeX Posted November 14, 2012 Report Share Posted November 14, 2012 I am having the same problem. I do EXACTLY what the manual says and when I hold HOME nothing happens. Any ideas? Quote Link to post Share on other sites
