scotto2323 Posted August 24, 2012 Report Share Posted August 24, 2012 What is the largest SD Card a z120BT will read? The manual looks like it says 16GB SDHC, but I someone said they used a 32GB card in another post. Can anyone confirm what works for me? Quote Link to post Share on other sites
Diverse Customs Posted August 25, 2012 Report Share Posted August 25, 2012 need that answer as well Quote Link to post Share on other sites
scotto2323 Posted August 27, 2012 Author Report Share Posted August 27, 2012 No one here is using SD cards? I am currently using 8GB so I can confirm that works. No one else with higher? I realize I can get a 16GB for only 10 bucks but would rather buy a 32GB for a couple bucks more if its gonna work. Quote Link to post Share on other sites
zx6rrdan Posted August 27, 2012 Report Share Posted August 27, 2012 The z120 card spec is FAT 16/32 so you should be fine with a 32GB card. I'm using a 32GB card in my x930 that has the same specs and work no problem. If your concerned buy the 32 somewhere you could return if it doesn't work. I'd suggest a fast (class 10) card for fast performance when filling the card. Remember that there is a limit of 300 folders 2500 files. Anything more it just won't show the files / folders. Quote Link to post Share on other sites
onevmo Posted August 28, 2012 Report Share Posted August 28, 2012 Using a 32GB SDHC Class 10 with my Z130BT and it works perfectly. I also used Guiformat at http://www.ridgecrop.demon.co.uk/index.htm?guiformat.htm it is quick and simple. Quote Link to post Share on other sites
