gidyup Posted August 29, 2012 Report Share Posted August 29, 2012 I received the 2012 map upgrade card (cnsd-300fm) and it asks for the device number in order to get a password. The instructions on the Pioneer upgrade site say go to settings > hardware. Problem is there is no "hardware" option in system settings or anywhere else that I can find. The only numbers available are "map version" and "version" and neither of those add up to the 16 digit code requested on the upgrade site. It appears that these instructions are for the 700HD, not the avic-F700BT. Then of course when I try to download the detailed instructions pdf for my model from their site I get a "file not found" error. Any help would be greatly appreciated. Quote Link to post Share on other sites
gidyup Posted August 29, 2012 Author Report Share Posted August 29, 2012 Please ignore...I found a European site with the instructions. Would it have killed Pioneer to have included this with the card???? Quote Link to post Share on other sites
pablofe Posted September 17, 2012 Report Share Posted September 17, 2012 If you run into this issue: turn the unit/car off insert the SD card you received with the upgrade turn the unit on the Device Number will appear and it will ask you for the password write down the Device Number go to https://www.pioneern...ationupdate.com get your password and start the upgrade And please, if you want the upgrade, buy it. -Pablo Quote Link to post Share on other sites
tail24 Posted September 17, 2012 Report Share Posted September 17, 2012 Agreed. One point of note and this is for people that have been forced to use my fixes. If you have had to do the Fromat MBR fix (like I did back when I bought this used unit that was completely bricked) you are loading a copy of someone elses complete avic. I believe this affects your device number now, so numerous poeple all have the same device number. Quote Link to post Share on other sites
