ryano2121 Posted October 21, 2012 Report Share Posted October 21, 2012 I am trying to wire in the parking brake bypass. I order the microbypass and will put that in when it gets here, but I want to see it work at least in the meantime. I understand that I need to connect the power side of a switch to the light green wire from the radio. I have built in switches in my truck, so I took power from it to the light green wire. Nothing happened. I verified there was power to the wire but nothing happened. So I tried grounding the light green wire and it worked. Why would it work with ground and not power? Quote Link to post Share on other sites
brucem1967 Posted October 24, 2012 Report Share Posted October 24, 2012 I purchased one on ebay. Worked like a dream http://www.ebay.com.au/itm/Pioneer-Video-Bypass-AVH-P5950DVD-AVH-P5900DVD-APP-Radio-AVH-5400DVD-AVH5400DVD-/380256243768?pt=LH_DefaultDomain_0&hash=item588909d038 Quote Link to post Share on other sites
pionara Posted October 24, 2012 Report Share Posted October 24, 2012 The PKB wire has always needed a ground (low signal) to activate. Where did you read that it uses power (high signal)? edit: if you look at the installation manual, i can see how its confusing. What's really happening when it is wired per the install manual is that when the parking brake switch is activated (because parking brake is on), the signal will be grounded. The grounding of PKB wire is actually what tells the unit that the parking brake is engaged. Quote Link to post Share on other sites
idelgado782 Posted October 25, 2012 Report Share Posted October 25, 2012 I purchased this switch from Radioshack http://www.radioshack.com/product/index.jsp?productId=3159591 and connected the green wire to #1 and I connected the ground to #2, I mounted it on a module and all I have to do is push the button once and i'm good to go! The switch cost me 2 bucks and I didn't have to wait for something to be delivered. I also purchased a relay just in case the switch didn't work but for now i'm happy. Quote Link to post Share on other sites
ryano2121 Posted October 27, 2012 Author Report Share Posted October 27, 2012 I read several places and watched a YouTube video saying to attach it to power. That was wrong for sure. I used a microbypass and it works great now. Quote Link to post Share on other sites
