R-S-B Posted November 6, 2012 Report Share Posted November 6, 2012 i have no past button in the supertestmode. i have make copy on sd card and want past in APL. i have no Button "paste". HELP me ...... Mfg RSB Quote Link to post Share on other sites
pionara Posted November 6, 2012 Report Share Posted November 6, 2012 I assume you mean "paste" - you might want to use "google translate" Please search youtube "avic testmode" and watch those videos Quote Link to post Share on other sites
R-S-B Posted November 6, 2012 Author Report Share Posted November 6, 2012 I assume you mean "paste" - you might want to use "google translate" Please search youtube "avic testmode" and watch those videos yes i paste i mean. thank you. wath can i do for copy from sd card to Apl Folder ? can you help ? Quote Link to post Share on other sites
R-S-B Posted November 6, 2012 Author Report Share Posted November 6, 2012 I assume you mean "paste" - you might want to use "google translate" Please search youtube "avic testmode" and watch those videos on youtube i find nothing wath can i use. Quote Link to post Share on other sites
pionara Posted November 6, 2012 Report Share Posted November 6, 2012 I am having a hard time understanding you but: You will only see the paste button if you have "copied" something first. Again, testmode file maintenance is very strange. You would need to watch some of the testmode videos to see how to navigate. Quote Link to post Share on other sites
R-S-B Posted November 6, 2012 Author Report Share Posted November 6, 2012 verry happy...... please. rearly... i go on my sd card in an folder with sume Files. select all and press copy. after i go to Apl Folder on my F930BT and want paste. but past is not active button in the Apl Folder. t makes me mad. I have even tried to automatic copy of condis Hack to copy myfolder Apl. -------------- REMOVE USER\PRG0\APL\Av1.exe REMOVE USER\PRG1\APL\Av1.exe COPY -c USER\PRG0\APL\Av.exe USER\PRG0\APL\Av1.exe COPY -c USER\PRG1\APL\Av.exe USER\PRG1\APL\Av1.exe REMOVE USER\PRG0\APL\Av.exe REMOVE USER\PRG1\APL\Av.exe COPY -rc SD\MikesHack\*.* USER\PRG0\APL ----------------------- but the script starts not : ScriptExec.ini http://www.roller-skate-berlin.de/wb/media/my_first_test.zip look please.... i think i am an newbe. i must learn sume... best regards mike Quote Link to post Share on other sites
thedmod Posted November 6, 2012 Report Share Posted November 6, 2012 Ok, this is a similar trap I fell into when trying to copy/paste files in testmode. Make sure you are navigating to the folders using the menus and not the home button. For example, if you go to the sd card, copy the file and then press home to get you back out, that copy is lost. You need to copy the file, scroll up to the "..." to get you up to the parent directory and select that. Only then will the item actually stay on your clipboard. Quote Link to post Share on other sites
pionara Posted November 6, 2012 Report Share Posted November 6, 2012 also, regarding ScriptExec.ini. There are different versions of testmode. There is "scripting" testmode.key, and original (regular "service" testmode) and then super ("developer" mode) of testmode scripting testmode.key will not go into the testmode screen, but instead run script commands in scriptexec.ini. That version of the key is included with condihack 2.x+ or autoreplacer Quote Link to post Share on other sites
R-S-B Posted November 7, 2012 Author Report Share Posted November 7, 2012 Ok, this is a similar trap I fell into when trying to copy/paste files in testmode. Make sure you are navigating to the folders using the menus and not the home button. For example, if you go to the sd card, copy the file and then press home to get you back out, that copy is lost. You need to copy the file, scroll up to the "..." to get you up to the parent directory and select that. Only then will the item actually stay on your clipboard. OK i understand.. i test it today. thank you first. Quote Link to post Share on other sites
R-S-B Posted November 7, 2012 Author Report Share Posted November 7, 2012 also, regarding ScriptExec.ini. There are different versions of testmode. There is "scripting" testmode.key, and original (regular "service" testmode) and then super ("developer" mode) of testmode scripting testmode.key will not go into the testmode screen, but instead run script commands in scriptexec.ini. That version of the key is included with condihack 2.x+ or autoreplacer thank you. i test today wath thedmod write. Quote Link to post Share on other sites
