JLs64 Posted April 10, 2013 Report Share Posted April 10, 2013 I want to confirm that you can get AUX Jack with the existing 30-pin cable. All you need is a female 30pin to Aux convertor and you can get aux input to the radio if you want Quote Link to post Share on other sites
VBLUE42 Posted April 10, 2013 Report Share Posted April 10, 2013 So are you saying that you have tried this and it did work? That may work if the iPod soft button on the touch screen will allow you to use it. Otherwise there is no selection on the touch screen to tell the unit to allow such an input. i may experiment with such an option to see for myself and report back. Quote Link to post Share on other sites
JLs64 Posted April 10, 2013 Report Share Posted April 10, 2013 Yes, but something i forgot to mentions is that you need to have the ipod connected to it. You need a regular USB-30pin connector like the white one that comes with the ipod and you need to connect that to the USB portion of the cable. That way the AR thinks that the ipod is connected and tries to get the signal through the cable. Then you can plug a 30pin-aux to get an AUX input to the AR2. I can provide a picture of what I did. Quote Link to post Share on other sites
VBLUE42 Posted April 10, 2013 Report Share Posted April 10, 2013 It would be interesting if that setup would work with the i5 configuration. As I said I may look into this out of curiousity. Quote Link to post Share on other sites
JLs64 Posted April 10, 2013 Report Share Posted April 10, 2013 i think this works because the way appraido works is that it verifies the ipod though USB line and thats where the icon on the screen becomes available and then get the input audio and video from the the ports on the 30-pin. they are analog so there is no need to convert them to digital(HDMI) so it will work if you just want to play your music by just having the setup and use the aux to connect it to the 3.5mm aux on the ipod/iphone. with this method you can even change the songs of your connected ipods as well with the album cover and infos of the song. Try it and Let me know how it works for you Quote Link to post Share on other sites
viivtodo Posted October 28, 2013 Report Share Posted October 28, 2013 Hello everyone, I have recently purchased a female dock to A2DP adapter from Amazon and can confirm that it works! (Link below) The only thing is that you have to connect the iPod before the adapter as stated before which is VERY annoying because sometimes I leave it plugged in hoping that once I start the car up again it will start in iPod mode again, but it doesn't. That being said, I have to unplug the A2DP adapter, plug in the iPod, unplug it, and then plug the adapter back in. Would there be any way to put resistors or a short circuit in the usb portion of the cable to make it think that the iPod is always plugged in? Thanks in advance for any insight you can offer. Link to the adapter: http://www.amazon.com/Patuoxun%C2%AE-Bluetooth-Receiver-Adapter-Sounddock/dp/B0094G44PS/ref=pd_sim_cps_5 Quote Link to post Share on other sites
chino73 Posted February 3, 2014 Report Share Posted February 3, 2014 Any luck with this? I upgraded to an Iphone 5s and I'm looking for an aux input option. I thought that I was going to be able to just leave an Ipod classic connected and use the Iphone if necessary, but it turns out I should change the connection option in settings . Also, I can't even allow both of them to charge because I need to plug the lightning cable for the Iphone. Thanks in advance! Quote Link to post Share on other sites
DDuB420 Posted February 8, 2014 Report Share Posted February 8, 2014 I wonder if this could work http://m.ebay.com/itm?itemId=310563388289 Add a female to female RCA adapter then red/white to female aux. Hook the hdmi end to an auto switch/remote switch hdmi splitter. One hdmi for phone the other for aux to the back of the deck. Not sure if it would detect the audio signal only without video through the hdmi port. Needs testing... Quote Link to post Share on other sites
Productthespic Posted March 1, 2014 Report Share Posted March 1, 2014 Anyome have luck with this using appradio 3? Quote Link to post Share on other sites
Daytona65 Posted April 10, 2014 Report Share Posted April 10, 2014 Unfortunately, I am stuck with an AppRadio 1.5 (SGH-100 I think). I recently swapped out my iPhone 4 for a Galaxy 4 and am totally bummed that I can't listen to my music anymore. I even tried my old school iPod nano, but it didn't even register - I got an error saying "unsupported something-or-other". I could deal with a 3.5 aux setup (like my stock stereo has) but I don't want to invest in parts I can't use - does anyone have a verified system for doing this (jack or bluetooth)? I'd appreciate a list of the hardware you used too. Thanks! Quote Link to post Share on other sites
wagnerbertolini Posted August 29, 2015 Report Share Posted August 29, 2015 Hello everyone, I have recently purchased a female dock to A2DP adapter from Amazon and can confirm that it works! (Link below) The only thing is that you have to connect the iPod before the adapter as stated before which is VERY annoying because sometimes I leave it plugged in hoping that once I start the car up again it will start in iPod mode again, but it doesn't. That being said, I have to unplug the A2DP adapter, plug in the iPod, unplug it, and then plug the adapter back in. Would there be any way to put resistors or a short circuit in the usb portion of the cable to make it think that the iPod is always plugged in? Thanks in advance for any insight you can offer. Link to the adapter: http://www.amazon.com/Patuoxun%C2%AE-Bluetooth-Receiver-Adapter-Sounddock/dp/B0094G44PS/ref=pd_sim_cps_5 Please, what was the device used? SPH-DA01? SPH-DA02? I am stuck on a SPH-DA01 and now I have an iphone 5, I just, only, want to listen to music. =/ I have an iphone 4 too, but I don't want to pay for two data plans (on both smartphones). And spotify did't work well there (i am running iOS 4.3.3, the fastest for music library). Thanks Quote Link to post Share on other sites
