shilly Posted January 18, 2013 Report Share Posted January 18, 2013 I apologize if this has been covered,I have searched and didnt come up with the proper answer.When doing the bypass on the x940bt, does hooking up the vss wire negate the bypass mod? Thanks in advance, Steve. Quote Link to post Share on other sites
pionara Posted January 18, 2013 Report Share Posted January 18, 2013 to my knowledge, no, if you are using the hardware bypass and grounding KMODE pin (aka moving the mute wire on a/v harness) Quote Link to post Share on other sites
dwilton Posted January 23, 2013 Report Share Posted January 23, 2013 I just finished installing my AVIC-X940BT in my 07 Hummer H3. I grounded the KMODE pin by moving the MUTE wire up in the connector. And, connected the VSS wire. Everything seems to be working perfectly. Quote Link to post Share on other sites
