s10blazer Posted February 6, 2013 Report Share Posted February 6, 2013 In the process of trying to install new maps x930bt, deleted the wrong files during copy and pastes process of test mode. After I messed that up, the unit tries to install and update and fails, the message states ''program update failed'', restarts, and tries to repeat the install process again and again and it fails every time. I can no longer enter test mode. What do I do? Any constructive help is greatly appreciated. Quote Link to post Share on other sites
aavica Posted February 7, 2013 Report Share Posted February 7, 2013 The same problem. Device reboot more & more. Test mode not wirking. I'm read service manual , may be file "ggs1098" needed? Please help urgently!!! Quote Link to post Share on other sites
pionara Posted February 7, 2013 Report Share Posted February 7, 2013 How are you trying to enter test mode? With sd card and testmode.key or by button presses? Try pulling radio fuse or power (both yellow and red wires) for 10 minutes or so. Quote Link to post Share on other sites
aavica Posted February 7, 2013 Report Share Posted February 7, 2013 How are you trying to enter test mode? With sd card and testmode.key or by button presses? Try pulling radio fuse or power (both yellow and red wires) for 10 minutes or so. I trying all of testmodes: 104bytes, 164bytes, 132bytes - the same resault. Cards was 2Gb, 4Gb and 16Gb, formatetd with fat32 and fat - the same. Device unplugged, and stay alone on the table So, I have full backup previosly state of device - NAND& NAND2, but how I can go to filemanager... Pressing to buttons (Home+ then 3xback-forvard) - not working. After upgrade all will be Ok, and testmodes was worked, but may be I delete same files from NAND... Here little video of curren state http://sendfile.su/757813 May be you know another methods, such as formating flash, or have another files to lay on SD (for example as described in service manual: How to Start-up Test Mode 1. Download GGS1098 from the Service Site. 2. Decompress the file. 3. Copy the decompressed file to the SD card root. 4. Insert the SD card to the product and turn ACC on )? Quote Link to post Share on other sites
s10blazer Posted February 7, 2013 Author Report Share Posted February 7, 2013 How are you trying to enter test mode? With sd card and testmode.key or by button presses? Try pulling radio fuse or power (both yellow and red wires) for 10 minutes or so. I am trying to enter using a sd card, how do I enter test mode another way? You mentioned something about buttons? what is that process? Quote Link to post Share on other sites
aavica Posted February 7, 2013 Report Share Posted February 7, 2013 I am trying to enter using a sd card, how do I enter test mode another way? You mentioned something about buttons? what is that process? Try this: keys combination to get into test mode manually by following: remove sd card, turn on ignition, keep home button pressed and press previous, next, previous, next and so on while keeping home button pressed until the unit restarts, it should enter testmode. In my case it does'nt working now Quote Link to post Share on other sites
s10blazer Posted February 7, 2013 Author Report Share Posted February 7, 2013 Try this: keys combination to get into test mode manually by following: remove sd card, turn on ignition, keep home button pressed and press previous, next, previous, next and so on while keeping home button pressed until the unit restarts, it should enter testmode. In my case it does'nt working now I just tried it! I did not work for me at all! SO this is where I am, Cant enter testmode both with an sd card or USB through Ipod cable I also cant enter test mode through holding home and track forward and back sequence. What other options do I have? Thanks in advance Quote Link to post Share on other sites
s10blazer Posted February 7, 2013 Author Report Share Posted February 7, 2013 How are you trying to enter test mode? With sd card and testmode.key or by button presses? Try pulling radio fuse or power (both yellow and red wires) for 10 minutes or so. I just tried it! I did not work for me at all! SO this is where I am, Cant enter testmode both with an sd card or USB through Ipod cable I also cant enter test mode through holding home and track forward and back sequence. What other options do I have? Thanks in advance Quote Link to post Share on other sites
aavica Posted February 16, 2013 Report Share Posted February 16, 2013 I just tried it! I did not work for me at all! SO this is where I am, Cant enter testmode both with an sd card or USB through Ipod cable I also cant enter test mode through holding home and track forward and back sequence. What other options do I have? Thanks in advance So, no any suggestions??? Quote Link to post Share on other sites
pionara Posted February 16, 2013 Report Share Posted February 16, 2013 if your unit does not boot into testmode with the following TESTMODE.KEY file placed on a FAT32 formatted sd card, then your unit is probably toast. supertestmode.zip Quote Link to post Share on other sites
aavica Posted February 17, 2013 Report Share Posted February 17, 2013 if your unit does not boot into testmode with the following TESTMODE.KEY file placed on a FAT32 formatted sd card, then your unit is probably toast. So is a toast Is any firmware updates? Quote Link to post Share on other sites
pionara Posted February 18, 2013 Report Share Posted February 18, 2013 So is a toast Is any firmware updates? If your unit does not boot into testmode, then it will not boot into regular mode which is required to do upgrade. So no. Quote Link to post Share on other sites
Shermanus Posted February 21, 2013 Report Share Posted February 21, 2013 Just "successfully" installed Condi Hackmode 2.21 to X930BT. Rebooted > Radio came on > Startup Screen. That's it. With or without SD Card - Same. Now I have a Radio. I can even change the stations by the Track buttons. Any suggestions ???? Thanks for help . Quote Link to post Share on other sites
Shermanus Posted February 21, 2013 Report Share Posted February 21, 2013 ****UPDATE**** Put the TESTMODE.KEY (Supertestmode) on the card and can get into the Testmode. What Now ? Thanks Quote Link to post Share on other sites
Shermanus Posted February 22, 2013 Report Share Posted February 22, 2013 UPDATE 2 - ************S O L V E D ************ Quote Link to post Share on other sites
