problem with navi
Since you've updated the n1 to the n2 software, the green wire being hooked up to the black wire will not work anymore. The lockout bypass for an n1 with n2 software is floating around here somewhere you'll have to search. Then do that. In the mean time what you can do is cut the green wire in half and put a toggle switch on it. You'll have to turn the switch off and then back on after the avic boots in order to do anything.
The newer software is what caused it. They made it harder to do stuff while you're moving with the newer versions and yours was bypassed to work with the original software, not the newer stuff
but thats sreally weird because it was always working and suddenly it jus stoped :S but i shall take it in and tell a installer to take a look
