Sanik Posted April 25, 2013 Report Share Posted April 25, 2013 I still do not understand what your problem is. Why did you removed something from somewhere? Add Igo 8.3-compatible maps to content\map folder. Igo cannot work without maps. Quote Link to post Share on other sites
Magosasueldo Posted April 25, 2013 Report Share Posted April 25, 2013 I still do not understand what your problem is. Why did you removed something from somewhere? Add Igo 8.3-compatible maps to content\map folder. Igo cannot work without maps. I don't removed anything. Igo8 begins to load (in the screen appears the logo igo) but a few seconds after the logo disappears and gray screen appears again. My device is the avic f940bt and the firmware is the 4.000. I hope I explained and I'm sorry for mi bad English Quote Link to post Share on other sites
Magosasueldo Posted April 25, 2013 Report Share Posted April 25, 2013 I don't removed anything. Igo8 begins to load (in the screen appears the logo igo) but a few seconds after the logo disappears and gray screen appears again. My device is the avic f940bt and the firmware is the 4.000. I hope I explained and I'm sorry for mi bad English I think my problem is the navigator. Igo8 stops when in the screen appears the logo igo8 and "language". I think but I can be wrong Quote Link to post Share on other sites
Sanik Posted April 26, 2013 Report Share Posted April 26, 2013 Please try this way! Add Igo 8.3-compatible maps to content\map folder. Quote Link to post Share on other sites
alexis99 Posted April 26, 2013 Report Share Posted April 26, 2013 I think my problem is the navigator. Igo8 stops when in the screen appears the logo igo8 and "language". I think but I can be wrong hola, puedes decirme donde bajo el pioneerus y como lo hago para pagar los 50 esos que dices? gracias Quote Link to post Share on other sites
Magosasueldo Posted April 26, 2013 Report Share Posted April 26, 2013 hola, puedes decirme donde bajo el pioneerus y como lo hago para pagar los 50 esos que dices? gracias Hola Alexis99. Tienes que enviar un privado a Sanik y el te dirá una cuenta de correo donde pagar los 50$ por paypal.. Después te envÃa un archivo de texto con instrucciones en inglés, un archivo con el pioneerus y un archivo con el navegador igo8 pero sin mapas. Si te animas a adquirirlo nos ponemos en contacto e intentamos sacarle el máximo rendimiento. Como ponÃa instalar el pioneerus es fácil. El problema lo estoy teniendo para insertar el navegador. Quote Link to post Share on other sites
Magosasueldo Posted April 29, 2013 Report Share Posted April 29, 2013 Yesterday I got it the navigator Igo8 run in the pioneer. The problem was that I erased the file language Russian. I am going to try install tomtom but I don't know where get it to install at pioneerus. Any idea? Quote Link to post Share on other sites
Magosasueldo Posted April 29, 2013 Report Share Posted April 29, 2013 OK GUYS. TomTom with sound!! How did you do it? I'm very interested to do run the tomtom in pioneerus. Thanks Quote Link to post Share on other sites
Sanik Posted April 29, 2013 Report Share Posted April 29, 2013 New version 1.2 avaible! What's new in V1.2 Fixed bug that sometimescaused reboots during first start of Pionerus. Brand new algohave been re-written fromscratch.As result now official navigation software does not loose connection tosatellites and that have increased stability of virtual GPS port. Fixed bug that caused screen freezingvolumeadjustment. New shell added to Pioneerus screen.Buttons and passes to navigation programs can be adjusted via editing"pioneerus.cfg" file. Some minor tweaks Quote Link to post Share on other sites
Schtiefv Posted April 29, 2013 Report Share Posted April 29, 2013 Aha that was what the email was about My russian is not that what it used to be anymore. Quote Link to post Share on other sites
Magosasueldo Posted April 29, 2013 Report Share Posted April 29, 2013 New version 1.2 avaible! What's new in V1.2 Fixed bug that sometimes caused reboots during first start of Pionerus. Brand new algohave been re-written from scratch.As result now official navigation software does not loose connection to satellites and that have increased stability of virtual GPS port. Fixed bug that caused screen freezingvolume adjustment. New shell added to Pioneerus screen. Buttons and passes to navigation programs can be adjusted via editing "pioneerus.cfg" file. Some minor tweaks How to do to upgrade? Quote Link to post Share on other sites
tufoz Posted April 30, 2013 Report Share Posted April 30, 2013 New version 1.2 avaible! What's new in V1.2 Fixed bug that sometimes caused reboots during first start of Pionerus. Brand new algohave been re-written from scratch.As result now official navigation software does not loose connection to satellites and that have increased stability of virtual GPS port. Fixed bug that caused screen freezingvolume adjustment. New shell added to Pioneerus screen. Buttons and passes to navigation programs can be adjusted via editing "pioneerus.cfg" file. Some minor tweaks Where's the download link and instructions? Thanks Quote Link to post Share on other sites
Sanik Posted April 30, 2013 Report Share Posted April 30, 2013 Magosasueldo, check you private messages, please. Quote Link to post Share on other sites
Magosasueldo Posted May 1, 2013 Report Share Posted May 1, 2013 Magosasueldo, check you private messages, please. Ok. Thanks Quote Link to post Share on other sites
luisdiogo Posted May 2, 2013 Report Share Posted May 2, 2013 Igo8 running on a F9210BT. Quote Link to post Share on other sites
