Bradrcr Posted March 31, 2013 Report Share Posted March 31, 2013 I am stuck with an F900BT and F90BT and I can't get backup camera functionality on either. I've tried this with both units (I know the F900 definitely worked on 3.0), where I've used two different wiring harnesses, and whether the Violet/White wire is run to my reverse trigger or even if I trigger it myself with a direct battery + input, the unit never switches to reverse. Obviously, I've double-checked the camera settings in the menu and turned it off/on to be certain. I have tested it with video running to the backup camera input as well in case that is the issue, and no luck. I do not get a black screen, there's literally no change in unit function when the wire is triggered. Any help or suggestion is appreciated, I'm really stuck now that I see both radios aren't working. Quote Link to post Share on other sites
Bradrcr Posted March 31, 2013 Author Report Share Posted March 31, 2013 Narrowing down the problem- I went ahead and ran the wiring back to the camera and retested it. I figured out that the camera will automatically come on during the booting of the stereo. Unfortunately, once it's done loading and the map is up, if I want to see the backup camera, I have to manually hit rearview in the AV source menu. Is there a setting I'm missing to get it to automatically switch sources? Quote Link to post Share on other sites
dblisle Posted April 25, 2013 Report Share Posted April 25, 2013 I'm having the same issue, I plugged a camera directly into the Brown RCA line and received a black screen. I occasionally get scan lines on the screen and the Reverse trigger won't work either. If anybody has any advice or is in the Keene, NH area I could definitely use the hand. AVIC F-700BT 4.01 Version Pyle PLCM18SC I would like to remain with this version since the 2.08 isn't compatible with the iPad Quote Link to post Share on other sites
dblisle Posted April 25, 2013 Report Share Posted April 25, 2013 UPDATE: Version 4.01 does not function with the back-up camera Version 3 does, only issue left is the Reverse Trigger Quote Link to post Share on other sites
Redeye Posted April 26, 2013 Report Share Posted April 26, 2013 UPDATE: Version 4.01 does not function with the back-up camera Version 3 does, only issue left is the Reverse Trigger I have an X-710BT running 4.01 and the reverse camera works just fine.... Quote Link to post Share on other sites
dblisle Posted May 5, 2013 Report Share Posted May 5, 2013 RedEye, That's good to know. I did manage to get the trigger working by reversing the polarity. However, I did notice that the camera occasionally freeze on the Back-Up Camera screen and wouldn't trigger when I placed the car in reverse after the initial start-up. -Dave Quote Link to post Share on other sites
