jp_kranenb Posted February 19, 2007 Report Share Posted February 19, 2007 So i bought an openbox n1 from a futureshop last year and had it installed. Now when i bought it, it was missing some stuff like nav discs but it was also missing the installation manual. So i've only had it in the car for like 10 months or so and there's been lots of other problems i've had to fix with the system and everything so i'm finally focusing on the headunit and want it all to work the way it should. When i'm on vehicle dynamics it wont show speedo or acceleration at all, was there something that they missed conecting? and if so what would be required for me to hook it up? thanks Quote Link to post Share on other sites
aznsmartass24 Posted February 20, 2007 Report Share Posted February 20, 2007 you get what you pay for. Why on earth would you buy an open box unit... especially a N1. They stopped making those years ago Quote Link to post Share on other sites
jp_kranenb Posted February 20, 2007 Author Report Share Posted February 20, 2007 cause i got it for a hundred bucks Quote Link to post Share on other sites
John@20Squared Posted February 21, 2007 Report Share Posted February 21, 2007 you get what you pay for. unfortunately he is right. there are certain things that you can get away with and certain things you can not. Stereo systems seem to be something that you never buy used or open box. Quote Link to post Share on other sites
cntrylvr79 Posted February 21, 2007 Report Share Posted February 21, 2007 Does the navigation work properly? If so then it's an issue with the vss wire either not being hooked up or not being hooked up right. Year/make/model of the car would be helpful Quote Link to post Share on other sites
jp_kranenb Posted February 21, 2007 Author Report Share Posted February 21, 2007 yeah everything works fine except for the vehicle dynamics and I drive a 96 honda civic cx. Quote Link to post Share on other sites
cntrylvr79 Posted February 21, 2007 Report Share Posted February 21, 2007 Ok go to the connection status screen and drive the car a bit. does the speed pulse number go up? If not then the vss wire is not hooked up or has a bad connection. Your vss if not hooked up is blue/white at the cruise control module under the driver's side dash. Quote Link to post Share on other sites
jp_kranenb Posted February 21, 2007 Author Report Share Posted February 21, 2007 um, the car doesn't have cruise control, so i'm guessing it wouldn't be in the cruise control module Quote Link to post Share on other sites
cntrylvr79 Posted February 21, 2007 Report Share Posted February 21, 2007 Ok then it should be the same color in a 20 pin harness above the fusebox in the driver's underdash. Quote Link to post Share on other sites
jp_kranenb Posted February 22, 2007 Author Report Share Posted February 22, 2007 sweet, thanks for the help Quote Link to post Share on other sites
