fredie121 Posted November 15, 2013 Report Share Posted November 15, 2013 Having a few issues with the below instructions, will remove the "Strike Through" once I got the process 100%. No guarantees for anyone who chooses to proceed as yet. It is possible to install the firmware for the Australian F940BT available here onto the F930BT There are a few steps involved in getting this to work: Download Condi's Hack v1.4 here Run as per instructions here to perform backup Goto "File Maintenance>USER" select all and Delete Download Condi's AutoInstall Hack v2.1 here and run System will start and display some message about something not found (Can't remember exact text) Follow the instructions for updating F940BT firmware as found here (Follow the Update Navigation part) Update will run and install files, once it restarts (Step 5 of the instructions), remove the SD card and restart unit. By doing this we are skipping updating uCom, not sure what function this performs. Proceed the Update Bluetooth firmware component of the instructions from step 6 of this tutorial. Your F930BT should now be updated and running the software of the F940BT with updated "AV Source" and connection functions for Apple devices using the Lightning Connector. AHA Radio will also be installed Quote Link to post Share on other sites
spamm_xxx Posted February 13, 2014 Report Share Posted February 13, 2014 Did u get this working? Quote Link to post Share on other sites
rpg Posted January 31, 2015 Report Share Posted January 31, 2015 Hi , Im in Australia, and found this link. Im looking to update my F930Bt firmware to F940BT firmware. All the links I found were for Europe. Has any one had any luck doing the update in Australia Quote Link to post Share on other sites
MrHulkey Posted February 9, 2015 Report Share Posted February 9, 2015 Hi, can someone post a how to do this hack for the F940BT in Australia PLZ. Quote Link to post Share on other sites
