lupohki Posted November 26, 2013 Report Share Posted November 26, 2013 I am using a Verizon Samsung Galaxy Note 3 with an AppRadio 2. I am using the MHL 2 adaptor in the link below which is for the newer Samsung phones Note 3, S3, and S4. When I try to connect, the bluetooth connection keeps failing at 75%. I tried unparing/pairing and initiating the bt connection manually, but it always fails at 75%. I had a Galaxy Nexus that I used with the AppRadio 2 fine. Has anyone else had this problem? Thanks. http://www.samsung.com/us/mobile/cell-phones-accessories/ET-H10FAUWESTA Quote Link to post Share on other sites
texbuck Posted November 26, 2013 Report Share Posted November 26, 2013 There are issues with Samsung's latest ota update working with the appradios. Did you allow an update to happen recently? Your adapter is the right one, by the way. Quote Link to post Share on other sites
lupohki Posted November 30, 2013 Author Report Share Posted November 30, 2013 I am using a Verizon Samsung Galaxy Note 3 with an AppRadio 2. I am using the MHL 2 adaptor in the link below which is for the newer Samsung phones Note 3, S3, and S4. When I try to connect, the bluetooth connection keeps failing at 75%. I tried unparing/pairing and initiating the bt connection manually, but it always fails at 75%. I had a Galaxy Nexus that I used with the AppRadio 2 fine. Has anyone else had this problem? Thanks. http://www.samsung.com/us/mobile/cell-phones-accessories/ET-H10FAUWESTA I figured out how to get my BT to connect. I have to leave the BT off on my phone and turn it on after the appradio is up and ready. Afterwards, I have to select to pair with the appradio on the phone and then it connects. It doesn't connect everytime, but I think I just need to play with the timing. Quote Link to post Share on other sites
