Sabre3487 Posted March 1, 2007 Report Share Posted March 1, 2007 Just curious if anyone knew where to tie into the VSS line on the 06 Lincoln Zephyr? Thanks, Burn Quote Link to post Share on other sites
cntrylvr79 Posted March 1, 2007 Report Share Posted March 1, 2007 My info says go to a wheel speed sensor. That's all no color or anything. Quote Link to post Share on other sites
Sabre3487 Posted March 1, 2007 Author Report Share Posted March 1, 2007 I am in contact with some of the mechanic guys at the lincoln dealer, there has to be a better way to access this wire. Anyone else?? Quote Link to post Share on other sites
MisFit Posted March 6, 2007 Report Share Posted March 6, 2007 There is no speed sense wire on the new platform Fords. You dont need it anyway.Pioneer Navis work fine in learn mode. But if you want, Alpine makes a speed pulse generator that you mount over the rear wheelwell in the trunk. Quote Link to post Share on other sites
Sabre3487 Posted March 6, 2007 Author Report Share Posted March 6, 2007 In the Zephyr the only way to get the pulse is to use one of the wheel speed sensors. I will post wire colors for you. It is an analog sensor so you would tap into the pos side. Burn Quote Link to post Share on other sites
