dvarapala Posted May 22, 2014 Report Share Posted May 22, 2014 When I installed my 8000NEX I permanantly grounded the parking brake input wire and then did the bypass. The bypass is working fine but every trip I have to click past an annoying message which says my parking brake input is not properly wired. I guess the bypass doesn't bypass the annoying nag screens. If I go back in there and wire the parking brake input properly I assume it will a) get rid of the nag screen, and have no effect on the operation of the bypass. Am I right? Quote Link to post Share on other sites
CuznVinny Posted May 22, 2014 Report Share Posted May 22, 2014 you didnt do the bypass right Quote Link to post Share on other sites
mab6680 Posted May 22, 2014 Report Share Posted May 22, 2014 that happens to me every once in a while maybe 3 or 4 times in the last 6 weeks but it doesnt happen every time Quote Link to post Share on other sites
dvarapala Posted May 24, 2014 Author Report Share Posted May 24, 2014 So while I had the console apart this morning to run some other wiring I went back and corrected the parking brake wiring also (i.e. instead of simply grounding it I hooked it up to the actual parking brake lead, just as Pioneer intended). After powering the unit back up and re-applying the nanny bypass, I threw in a DVD to play while I drove over to the Post Office. I'm happy to report that the nanny bypass still works and the "your parking brake is miswired" nag screens are gone!! WooHoo!!!! Now if I could just get these AppRadio mode bugs fixed... Quote Link to post Share on other sites
Shackleton Posted May 25, 2014 Report Share Posted May 25, 2014 Quote Link to post Share on other sites
