jhren Posted June 24, 2014 Report Share Posted June 24, 2014 Going to be installing an 8000NEX in a conversion van (2000 Chevy Express base). The OEM unit is larger than single din yet smaller than double din, and also had the premium package with CD drive below it. Currently has a single din HU installed with aftermarket adapter and an OEM utility pocket replacing the CD drive. Here's a picture an OEM unit with the pocket I found on 'net... Not currently concerned with actual mounting of the unit behind the instrument panel bezel. With the OEM unit not being double din to begin with, I'm not having any luck finding an easy means to make the trim out respectable. An aftermarket bezel with double din opening would be ideal. Otherwise, I'll have to cut out the 'bar' between the OEM unit and pocket in the picture. While cutting it presents no problem, it leaves the problem of concealing or somehow trimming out the cut edges. Suggestions, tips, recommendations, any help at all appreciated Quote Link to post Share on other sites
drenyce311 Posted June 24, 2014 Report Share Posted June 24, 2014 i would just remove the bottom pocket to make it fit. Then start doing some custom work. Quote Link to post Share on other sites
jhren Posted June 24, 2014 Author Report Share Posted June 24, 2014 i would just remove the bottom pocket to make it fit. Then start doing some custom work. Yeah, I got that. I'm asking about after that... Quote Link to post Share on other sites
VBLUE42 Posted June 24, 2014 Report Share Posted June 24, 2014 Get a double din kit for the dash and be done with it. Quote Link to post Share on other sites
tekki Posted June 24, 2014 Report Share Posted June 24, 2014 Personally I would rather have the temp controls moved down, if there isn't stuff blocking inside the dash and custom install the nex up top, then make, or have made a custom faceplate. I don't like the radio so low, I don't like having to look down so far. Quote Link to post Share on other sites
jhren Posted June 24, 2014 Author Report Share Posted June 24, 2014 Get a double din kit for the dash and be done with it. You have a specific kit in mind? I have not found one specifically for the 2000 Express... Quote Link to post Share on other sites
jhren Posted June 24, 2014 Author Report Share Posted June 24, 2014 Personally I would rather have the temp controls moved down, if there isn't stuff blocking inside the dash and custom install the nex up top, then make, or have made a custom faceplate. I don't like the radio so low, I don't like having to look down so far. That's a good idea. Once I get the dash apart, I'll have to check whether the temp controls can be moved to the bottom. Trim out will still be the big question. Quote Link to post Share on other sites
mab6680 Posted June 24, 2014 Report Share Posted June 24, 2014 a google search will bring up a number of double din dash kits for your van Quote Link to post Share on other sites
jhren Posted June 24, 2014 Author Report Share Posted June 24, 2014 a google search will bring up a number of double din dash kits for your van Been there, done that. When you follow the hit links, you'll find that they are not specifically for the 2000 model year... usually later model years. Then I have run across the ones that say double din, but alas, they are not. Here's an example: One of the google hit links leads here... http://www.brentwoodcaraudio.com/Chevrolet_Radio_Installation_Dash_Kits_s/104.htm?searching=Y&sort=7&cat=104&show=60&page=1 Then find the one on that says its single or double din... http://www.brentwoodcaraudio.com/Chevy_Express_Radio_Dash_Kit_p/express%201996%20-%202000%20dash%20kit.htm Take a look at the picture. It's not a double din kit. Please provide a direct link if you find one... Quote Link to post Share on other sites
drenyce311 Posted June 24, 2014 Report Share Posted June 24, 2014 Yeah, I got that. I'm asking about after that... Get your filler and start shaping. As for the brackets you will need to fabricate a bracket that bolts on the existing 1.5 radio bolt locations. Quote Link to post Share on other sites
jhren Posted June 24, 2014 Author Report Share Posted June 24, 2014 Get your filler and start shaping. As for the brackets you will need to fabricate a bracket that bolts on the existing 1.5 radio bolt locations. Trying to get by without going that route... but may have to Quote Link to post Share on other sites
