mikelr94 Posted March 15, 2007 Report Share Posted March 15, 2007 I just finished intall of my D2 with reverse camera, my problem is the reverse switch function doesn't seem to be working right. My vehicle is a 07' DodgeRam, I am using a PAC harness adaptor to get the vss signal and reverse input. The camera works in the split screen (rear view) mode but won't switch to full screen when putting the truck in reverse. I noticed that upon start up once the D2 boots up it goes to a black screen with the warning message about reverse mirror images at the bottom of the screen. I then put the truck in reverse and there it was, full screen back-up camera display!! If I press either the AV or MAP buttons the display switches back to Nav or AV mode and I can't get the reverse camera screen back until I power cycle the D2. Any ideas??? Quote Link to post Share on other sites
mikelr94 Posted March 20, 2007 Author Report Share Posted March 20, 2007 Looks like the issue was the PAC harrness adapter was malfunctioning and not giving the reverse gear signal. The polarity setting was set to ground so during boot up it would see a ground I guess and toggle to rear camera until you selected a different function. Quote Link to post Share on other sites
cntrylvr79 Posted March 21, 2007 Report Share Posted March 21, 2007 Try changing the polarity that the avic looks for to switch to reverse cam. Quote Link to post Share on other sites
mikelr94 Posted March 21, 2007 Author Report Share Posted March 21, 2007 I tried that first off, that's how I ended up getting the reverse camera screen upon boot up. I had left the setting on Neg mode. I have checked the PAC bus adapter with a meter shifting the transmission in and out of reverse yields no change in the reverse gear output Looks like I need to send the harness adapter back... Oh the down time... Quote Link to post Share on other sites
cntrylvr79 Posted March 21, 2007 Report Share Posted March 21, 2007 Well if you don't want the down time you can pick up the reverse here. Reverse Light white/lt. green + harness at top of driver fender Quote Link to post Share on other sites
tmartin000 Posted April 13, 2007 Report Share Posted April 13, 2007 Mike-- Did you find the adapter was to blame??? I am using the same adapter for my 06 Ram. I have yet to get the cam installed and want to avoid the same issue......... Tom Quote Link to post Share on other sites
