sethb Posted March 31, 2007 Report Share Posted March 31, 2007 hi yall! i have lurked these forums since before i got my z1, you all have been very helpfull. ok on to my problem. i had a z1 installed in jan. 07 and everything worked fine. i recently had it bypassed though and i get the parking brake error (which is normal if im not mistaken) and my voice command is gone. helllllllp! lol Quote Link to post Share on other sites
bobmun Posted March 31, 2007 Report Share Posted March 31, 2007 try a reset, also make sure the mic is plugged in and in the right port. Quote Link to post Share on other sites
sethb Posted March 31, 2007 Author Report Share Posted March 31, 2007 try a reset, also make sure the mic is plugged in and in the right port. will the reset "reset" all of my settings? or will i loose any saved destinations? Quote Link to post Share on other sites
ducatiboy Posted March 31, 2007 Report Share Posted March 31, 2007 No do a level 1 reset, which is the recessed button to the right of the eject button on the bottom-left of the unit. You will lose your saved AM/FM presets, and possibly your audio settings (sound stage and different EQ presets) stuff like that. You won't lose any nav or stored music. That will get rid of that parking brake message. Did that pop up after you did the bypass? If so your bypass is not working right. When was your Z1 manufactured? Then check this: http://www.sminntech.com/z1flash.html And double check your bypass. This makes me thing you have a July 06 or newer and you missed wired #2. http://www.sminntech.com/z1flash.html#newbypass That's what will cause what you talk about. Quote Link to post Share on other sites
sethb Posted April 1, 2007 Author Report Share Posted April 1, 2007 No do a level 1 reset, which is the recessed button to the right of the eject button on the bottom-left of the unit. You will lose your saved AM/FM presets, and possibly your audio settings (sound stage and different EQ presets) stuff like that. You won't lose any nav or stored music. That will get rid of that parking brake message. Did that pop up after you did the bypass? If so your bypass is not working right. When was your Z1 manufactured? Then check this: http://www.sminntech.com/z1flash.html And double check your bypass. This makes me thing you have a July 06 or newer and you missed wired #2. http://www.sminntech.com/z1flash.html#newbypass That's what will cause what you talk about. thanks! ok, i reset it and the parking brake warning is gone! thats cool. but voice command is still not back. i will get them to look at it again and make sure the correct wires are grounded. Quote Link to post Share on other sites
bobmun Posted April 1, 2007 Report Share Posted April 1, 2007 also make sure the mic is plugged into the right port. Quote Link to post Share on other sites
ducatiboy Posted April 1, 2007 Report Share Posted April 1, 2007 If the parking brake warning comes back (try doing something like DVD while driving, and don't pay attention to the dvd for safety reasons) and start moving and see if the parking brake warning comes back. And when you say the voice command is gone.... do you mean: #1 The voice command icon is no longer present on the screen. or #2 The voice command icon is there but when you press it, it doesn't hear you. If it's #1, then bobmum is right the mic plug is not inserted into the back of the z1 or in the wrong location. if it's #2 then the mic wire is pinched and cut somewhere. Try a new mic. Quote Link to post Share on other sites
