ogx3og Posted April 1, 2007 Report Share Posted April 1, 2007 Going to be installing a D1 into my 05 Altima. Hopefully all goes well. I will post pics when done. Quote Link to post Share on other sites
JHG120 Posted April 1, 2007 Report Share Posted April 1, 2007 Nice. I just did a D2 in 05 Altima. Rather tricky, and you'll have to let me know which screw holes you used on the factory mounting bracket to install the D1. If it's the same as with my D2, there will be a rather big gap. I put several washers behind the mounting screws, and that helped alittle bit. The VSS wire is on the bigger factory harness. Looking at the wire side, it will be on the bottom right, far corner, and it should be light pink. I called crutchfield, but they said that wasn't it, but I hooked it up and the speed sense confirms that is the VSS wire. To install factory steering wheel controls, use the factory harness plug that IS NOT used by the aftermarket D1/D2. It will only have 3 wires, that controls the entire LEFT side of your steering wheel controls. Bypass was simple, as there are tons of other threads here as well. Just be careful removing the "cellular mute" wire, as I bent the connector, but was still able to re-bend it and use it. I'll include pics of my install this afternoon. Good luck, and PM me if you need some help. Quote Link to post Share on other sites
ogx3og Posted April 5, 2007 Author Report Share Posted April 5, 2007 Here's a pic. I don't know how to show more then one in a post. It's all done. Didn't take too long. If anyone does this is a 2.5s VSS is behind instrument cluster. Quote Link to post Share on other sites
JHG120 Posted April 5, 2007 Report Share Posted April 5, 2007 Looks very nice. Your's sits much farther forward then mine. Did you use anything special to get it that way. Here are pics of mine, just click or copy. http://i130.photobucket.com/albums/p263 ... G_0391.jpg http://i130.photobucket.com/albums/p263 ... G_0392.jpg http://i130.photobucket.com/albums/p263 ... G_0393.jpg Quote Link to post Share on other sites
