shockme66 Posted April 5, 2007 Report Share Posted April 5, 2007 Any clue what color the reverse wire is. Thanks Quote Link to post Share on other sites
MisFit Posted April 6, 2007 Report Share Posted April 6, 2007 this is for an 06, not sure if it has changed Reverse Lights RED (+) ECU PIN13 PSC/ECU TO THE FAR RIGHT BEHIND GLOVE BOX Quote Link to post Share on other sites
shockme66 Posted April 10, 2007 Author Report Share Posted April 10, 2007 I am trying to find the reverse wire in the driver kick panel. I thought I traced it down to a red/black wire and it worked, but only when the car it turned to BAT, if I start the car it does not work. Do you know which wire in the kick it its, I just dont feel like pulling everything apart and running the wire to the glove. Thanks so much. Quote Link to post Share on other sites
MisFit Posted April 10, 2007 Report Share Posted April 10, 2007 dont be lazy, in the time it took you to write this post you could have ran the wire and been done already. and the glove box is closer to your radio than the kick panel anyway Quote Link to post Share on other sites
shockme66 Posted April 10, 2007 Author Report Share Posted April 10, 2007 I dont want to be lazy, but everything is perfectly in place at this point, and I didnt want to rip everything apart. So I guess you dont know the color wire? If not I will have to rerun the wire. Quote Link to post Share on other sites
MisFit Posted April 10, 2007 Report Share Posted April 10, 2007 its listed at the ecu because thats where it is. and if its behind the glove box, then it probably runs down the passenger side anyway. Quote Link to post Share on other sites
