powa Posted April 17, 2007 Report Share Posted April 17, 2007 I find the routing is off when I am at downtown area with lots of tall building, is there a GPS antenna booster for the D3? Quote Link to post Share on other sites
whtcrxghst Posted April 17, 2007 Report Share Posted April 17, 2007 No, that is what the VSS/3D hybrid is for Quote Link to post Share on other sites
powa Posted April 17, 2007 Author Report Share Posted April 17, 2007 No, that is what the VSS/3D hybrid is for what does that mean exactly? Quote Link to post Share on other sites
whtcrxghst Posted April 17, 2007 Report Share Posted April 17, 2007 It means if you connect your VSS wire, it will learn. Then using the VSS info, gyro, and previous information it should still know your approximate location even when reception is blocked (like bridges, buildings downtown, etc.) Quote Link to post Share on other sites
fenguin Posted April 17, 2007 Report Share Posted April 17, 2007 My accuracy increased dramatically when I mounted the GPS outside of the car versus inside. Quote Link to post Share on other sites
jaytrey Posted April 21, 2007 Report Share Posted April 21, 2007 hi guys...quick question: i had my antenna sitting on my dash before and i was worried that it was too obvious to outsiders. i moved it inside the dash behind the unit itself. however, i forgot to check the connection status before putting it inside. after i put it inside the dash, i looked at the status. at the green antenna that has bars has one bar...but the pics behind it have 6-7 orange sats. can anyone tell me what is optimal and what i'm suppose to be expecting? thanks guys Quote Link to post Share on other sites
