Dougw133 Posted November 23, 2014 Report Share Posted November 23, 2014 Two things. 1- Back up camera. Very confusing read in the manual on the modes. I currently have a camera installed. I have it hard wired to battery power and is triggered on by a relay to my ign wire. I have been doing electrical for years. So basiacally turn the car on, relay trips and the camera has power. I really want to be able to simply toggle the camera on and off. I dont see any option to do it other than in the settings menu. When I do, the camera wants to stay on all the time and I have to hold MODE for 5 seconds to get back. Is there really no AV shortcut or something to toggle the camera view? I am going to hook up the purple wire to my reverse light trigger tomorrow. 2-SD card file sorting. I have a standard music library Artist-->Album-->Songs etc.. When I play all the unit starts them Alphabetically ALL SONGS. So basically when Im listening and want to take it off shuffle and just listen to that album, I cannot. It also does not allow me to skip backwards. This seems ridiculous. This is my first modern Pioneer unit in a long time. Is there no way to set sorting options? Artist, album, song track number and Alphabetically? I am using a 256gb SD card in NTFS. Thanks in advance. Quote Link to post Share on other sites
mab6680 Posted November 25, 2014 Report Share Posted November 25, 2014 holding the map button will turn the camera after that if you touch the screen it will toggle back the the regular screen or press the X on the camera screen to turn it off Quote Link to post Share on other sites
Phatreno Posted November 26, 2014 Report Share Posted November 26, 2014 if your trying to turn on camera manually and with out going thru settings you could trigger reverse wire off head unit with a toggle switch,just diode it so it doesn't back feed to reverse lights Quote Link to post Share on other sites
Dougw133 Posted November 30, 2014 Author Report Share Posted November 30, 2014 if your trying to turn on camera manually and with out going thru settings you could trigger reverse wire off head unit with a toggle switch,just diode it so it doesn't back feed to reverse lights Thanks for the replies. Got the reverse wired up, working well. Just can't believe there's no quick toggle button in the AV menu. I dont have a navi unit so there's no map button. Actually Im not suprised, this is pioneer we're talking about. Quote Link to post Share on other sites
