cpages2 Posted May 2, 2007 Report Share Posted May 2, 2007 Anyone know what wire I tap on the Gauge cluster of an 07' STI for VSS (AVIC-D2)? Thanks, Mike Quote Link to post Share on other sites
tillithz Posted May 2, 2007 Report Share Posted May 2, 2007 search, theres a thread here on that or two. you could always search the net for info on the ecu pin outs as well. That would probably be an easier, more clean spot to go for your wires, especially since the reverse is in the pass kick panel anyways. Quote Link to post Share on other sites
99 rs Posted May 2, 2007 Report Share Posted May 2, 2007 nasioc.com has all the pinouts of the cluster. I can't give you a direct link but while I was on there I heard it going around. Post a question there and you'll probably get your answer within 5 minutes. There are a 100 000+ members on there. Quote Link to post Share on other sites
cntrylvr79 Posted May 3, 2007 Report Share Posted May 3, 2007 Too hard to search? http://avic411.com/forum/viewtopic.php? ... highlight= Quote Link to post Share on other sites
PCGuRu2K Posted May 4, 2007 Report Share Posted May 4, 2007 if it's an '05 and up STI then it'll be the Dark Green/Black wire farthest to your right behind the gauge cluster. I did my D3 last weekend and that's what I used on my '07. Works perfectly fine Quote Link to post Share on other sites
