rastaman Posted May 10, 2007 Report Share Posted May 10, 2007 ok...i got the vtl 300 plate cam but when i put it on map rear view mode (and im in park) it comes out black completely whats the problem? i had a "pro" install it...should ii take it back? it works when i go to put it on reverse but i need to have the ability to check when i need to ...someone help please Quote Link to post Share on other sites
rastaman Posted May 10, 2007 Author Report Share Posted May 10, 2007 uppin for help Quote Link to post Share on other sites
cntrylvr79 Posted May 10, 2007 Report Share Posted May 10, 2007 Take it back. They hooked power up for the camera to the reverse wire, not accessory like it should be. Quote Link to post Share on other sites
hvs69 Posted May 10, 2007 Report Share Posted May 10, 2007 cntrylvr79 is absolutely right. I have the same camera. I have connected the red wire to the 12V signal (Ignition) going to my headunit. It works whenever I switch to rear-view mode irrespective of whether I am parked or driving. Quote Link to post Share on other sites
Creative Posted August 3, 2007 Report Share Posted August 3, 2007 I am having a similar problem, I am just getting white lines across the screen whether it is in reverse or camera mode. I switched the camera mode from battery to gnd to see if it would make a difference but it did not. Any suggestions? Nevermind - just found out I had a bad ground! Quote Link to post Share on other sites
