miraluna Posted May 18, 2007 Report Share Posted May 18, 2007 Can you post up the location and colors of the Reverse wire and the VSS wire for the 92 lexus SC300? Thanks. Quote Link to post Share on other sites
miraluna Posted June 26, 2008 Author Report Share Posted June 26, 2008 Help!!! Quote Link to post Share on other sites
Julius Posted June 26, 2008 Report Share Posted June 26, 2008 This is as close as I could get to your car.This is for a 1991 but it may be the same color and location as your car.Check with meter before you connect the wire.You can run a wire to your backup lights for the reverse wire. VSS Wire Silver/White Behind Glove Compartment Pin 12 of ECM Quote Link to post Share on other sites
