DrCute Posted June 18, 2007 Report Share Posted June 18, 2007 Hey all i see that each and every post about gets some valid responses and you all help each other out. i just recently got a N1 and im having some issues trying to put backround pics up. Can someone please list me out a specific way on how to transfer to avic. Pioneers way does not seem to be working. Thanks in advance, Eddie 2004 Jeep Wrangler Rubicon 2 12" Alpine type R's Ipod Adapter Xm Adapter Quote Link to post Share on other sites
PaisanNYC Posted June 18, 2007 Report Share Posted June 18, 2007 you must be burning the files the wrong way. The Pioneer instructions work just fine. Quote Link to post Share on other sites
action Posted June 19, 2007 Report Share Posted June 19, 2007 not sure if this is valid with the N-series, but with the Zs, you cannot simply use windows to burn the CD. You must use a 4rd-party (nero, roxio, etc.). Quote Link to post Share on other sites
Vinniety Posted August 16, 2007 Report Share Posted August 16, 2007 Does anyone have the pioneer instructions on how to upload the pictures to a Avic N1? Disregard i found it on the pioneer web site.. In the menu operation screen, you can indicate a picture you like on the background. Some pictures are already stored, but you can also use pictures (JPEG format data) created by a personal computer or a digital camera. If you save the pictures to a CD-R (or CD-RW), you can use them as background pictures. The following two types of background pictures can be changed: AV Background : Background for the screen during the operation of audio, or during playback. Navigation Background : Background of navigation menu screen. Several background pictures are stored in the Pioneer DVD map disc. If you want to use these pictures, insert the Pioneer DVD map disc. Here, a method of changing background picture is described with an example of loading the picture stored on a CD-R (-RW) onto the navigation system as the background picture. When storing original pictures on a CD-R (-RW), create a folder named BG in a CD-R (-RW), and store the picture files in this folder. Up to 20 picture files can be used in the BG folder. When creating a Background Picture Setting CD-R (-RW) for changing the navigation unit background picture, make sure the total data size of the CD-R (-RW) is greater than 100MB. However, you cannot use a CD-R (-RW) containing MP3 files or the Audio data part (CD-DA session) for the Background Picture Setting function. 1. Insert a CD-R (-RW) to the disc loading slot. 2. Touch Settings in the Main menu, then touch Background Picture Setting. The picture selected for each screen is indicated on the right side of AV Background and Navigation Background items. 3. Touch Navigation Background or AV Background. 4. Touch Import from Disc. The list of the pictures stored in a CD-R (-RW) is displayed. 5. Touch a picture you want for the background. 6. Select how to display the picture. You can select the following items: Center: Selected picture is displayed at the center of the screen. Repeat: Selected picture is patterned, and displayed as covering the whole screen. Note: When selecting images already stored on the Pioneer DVD map disc, you cannot select the layout method for those images. The background image starts changing. After a short while, the new background image appears. 7. Touch done. Notes: Only JPEG format (.jpg or .JPG) pictures can be used as a background picture. You can only use standard characters (alphabets of both cases: A-Z, a-z) and numbers (0-9) for the file name of a background picture (international (accented) characters cannot be used). Pictures up to a maximum of 2048×1536 pixels can be used. We cannot guarantee a proper operation for a picture bigger than this size. Progressive format JPEG pictures cannot be used. When changing a picture starts, do not cut off the vehicle engine until the message informing the completion of changing a picture is indicated. When the Navigation System is reset, or the language setting is changed, the Background picture may change back to the original picture. If this happens, set the background picture again. Quote Link to post Share on other sites
