Thermo144 Posted August 7, 2007 Author Report Share Posted August 7, 2007 Ok. The manual says that the two options are 1. Tuner - Extends the antenna only for the Radio source. The antenna is stored when the source is switched to another source. and 2. Power - Extends the antenna when the ignition switch is turned on. The antenna is stored when the ignition switch is turned off. So, if I set it on the "Power" option, it would turn the amp on when I turn my car on, and then turn it off when I turn the car off? Quote Link to post Share on other sites
cntrylvr79 Posted August 7, 2007 Report Share Posted August 7, 2007 That's it. Quote Link to post Share on other sites
Thermo144 Posted August 7, 2007 Author Report Share Posted August 7, 2007 Your good. The harness should be here on Wed. Fingers crossed this weekend, and I may actually make this work! Quote Link to post Share on other sites
cntrylvr79 Posted August 7, 2007 Report Share Posted August 7, 2007 Best of luck. Quote Link to post Share on other sites
