josh352727 Posted August 20, 2007 Report Share Posted August 20, 2007 installed d3 last night, had question bout illumination wire. wire colors matched dimmer wire colors, so ignored colors and hooked it up to dash illumination wire. does that sound right? should it switch fom day to night with ill? bypass works flawless ty avic 411. Quote Link to post Share on other sites
steve310 Posted August 20, 2007 Report Share Posted August 20, 2007 Is it not working? Your post is a little difficult to understand. When you turn on your headlights, the D3 should dim and go into night mode. If the "si" you are talking about is a Civic, the wire you should have hooked it up to is the red wire with a black stripe. If you used a harness, just see which wire corresponds with that one. Quote Link to post Share on other sites
josh352727 Posted August 20, 2007 Author Report Share Posted August 20, 2007 trying to be short keyboard stopped working and im using the onscreen yes a civic ok so color on harness does not match, pioneer is orange and orange on harness is for dimmer. orange/white is ill. on harness so thats what i connected it to. should map display change from day to night with ill. hooked up? thanx 4 reply Quote Link to post Share on other sites
whtcrxghst Posted August 20, 2007 Report Share Posted August 20, 2007 Yes, the map screen should switch to black when you turn on your headlights trying to be short keyboard stopped working and im using the onscreen yes a civic ok so color on harness does not match, pioneer is orange and orange on harness is for dimmer. orange/white is ill. on harness so thats what i connected it to. should map display change from day to night with ill. hooked up? thanx 4 reply Quote Link to post Share on other sites
Superchiu Posted August 21, 2007 Report Share Posted August 21, 2007 If you used an aftermarket Honda harness for your D3, you should connect the orange wire on the harness to the "Illum" wire on the D3. Quote Link to post Share on other sites
josh352727 Posted August 21, 2007 Author Report Share Posted August 21, 2007 the orange wire on aftermarket harness said dimmer, the orange/white said illumination so thats the one i used. its working, but had two dash lights go out was wondering if this could be the cause. Quote Link to post Share on other sites
