Is it not working? Your post is a little difficult to understand.
When you turn on your headlights, the D3 should dim and go into night mode.
If the "si" you are talking about is a Civic, the wire you should have hooked it up to is the red wire with a black stripe. If you used a harness, just see which wire corresponds with that one.
trying to be short keyboard stopped working and im using the onscreen
yes a civic
ok so color on harness does not match, pioneer is orange and orange on harness is for dimmer. orange/white is ill. on harness so thats what i connected it to.
should map display change from day to night with ill. hooked up?
thanx 4 reply
Yes, the map screen should switch to black when you turn on your headlights
yes a civic
thanx 4 reply
