Problem burning Z2 bypass
Okay, I've tried everything I know to do. I am trying to bypass my Z2 by loading the ISO that I found in several of the post. The problem I'm having is that when I load the disk, nothing happens. It tells me that the disk was loaded and it appears to try and load it but then Nothing.
Any suggestions fellas?
Did you hit MAP? (you will need the parking brake on or the wire grounded to be able to hit "yes" when it asks you to update)
When you burned the ISO did you put the ISO file on a DATA CD? Or did you use a burning program to use the ISO to create a CD?
What is the list of files on your CD?
