talkin73 Posted April 25, 2015 Report Share Posted April 25, 2015 After my 8100 was installed and the installer did a "bypass" using a module that they typically use, the nav screen said "Speed Limit wire is not connected. Will operate in Simple Hybrid Mode." What does that mean? Quote Link to post Share on other sites
huddy Posted April 26, 2015 Report Share Posted April 26, 2015 It's means that your VSS aka "speed wire" isn't connected. You can do a quick search on here for those terms and get the detail on what that does. The unit will work fine in Simple Hybrid Mode as long as you have a GPS signal. Quote Link to post Share on other sites
talkin73 Posted April 26, 2015 Author Report Share Posted April 26, 2015 It's means that your VSS aka "speed wire" isn't connected. You can do a quick search on here for those terms and get the detail on what that does. The unit will work fine in Simple Hybrid Mode as long as you have a GPS signal. huddy, thanks very much. Quote Link to post Share on other sites
huddy Posted April 27, 2015 Report Share Posted April 27, 2015 Yeah, I just read through a lot of posts on it. Basically it taps into speedometer speed pulse wire. The unit then knows that the car is moving and at what rate. Important when you lose GPS signals like going into tunnels, heavily forested areas, lots of tall buildings ect...so the nav keeps functioning vs hanging up waiting to reconnect with the lost satellites. It also helps with making turm notifications a bit sharper/sooner vs last minute. Also has some effect on the ASL feature (automatic sound leveliser) that lowers/increases the radio volume as you go slower/faster. I've had my unit (6000) running in Simple Hybrid Mode for 6 months now without the VSS wire attached and haven't had any nav issues. Done a few 600 mile+ round trips and nav works like a champ. Quote Link to post Share on other sites
talkin73 Posted April 27, 2015 Author Report Share Posted April 27, 2015 Yeah, I just read through a lot of posts on it. Basically it taps into speedometer speed pulse wire. The unit then knows that the car is moving and at what rate. Important when you lose GPS signals like going into tunnels, heavily forested areas, lots of tall buildings ect...so the nav keeps functioning vs hanging up waiting to reconnect with the lost satellites. It also helps with making turm notifications a bit sharper/sooner vs last minute. Also has some effect on the ASL feature (automatic sound leveliser) that lowers/increases the radio volume as you go slower/faster. I've had my unit (6000) running in Simple Hybrid Mode for 6 months now without the VSS wire attached and haven't had any nav issues. Done a few 600 mile+ round trips and nav works like a champ. Hmm. You got my attention with the ASL. I actually find this a useful feature but makes sense it can't work if the HU doesn't know the speed. May need to have my installer connect the wire if for no other reason than this one. Thanks again. Very succinct and helpful overview! Quote Link to post Share on other sites
kingoftypos Posted April 27, 2015 Report Share Posted April 27, 2015 I hope you didn't pay for that "bypass module". As you can do the bypass very easily from the screen. I personally installed this unit as well as my previous Pioneer D-3. Both times I used the speed sense wire. I travel in areas where the GPS signal doesn't reach, like a mile inside the tunnel. Either through a mountain or through the Chesapeake Bay Bridge Tunnel. KOT Quote Link to post Share on other sites
talkin73 Posted April 28, 2015 Author Report Share Posted April 28, 2015 I hope you didn't pay for that "bypass module". As you can do the bypass very easily from the screen. I personally installed this unit as well as my previous Pioneer D-3. Both times I used the speed sense wire. I travel in areas where the GPS signal doesn't reach, like a mile inside the tunnel. Either through a mountain or through the Chesapeake Bay Bridge Tunnel. KOT I did pay them $15 for the module. Given that I have no install skills and they are a very well-respected company with whom I've done business on numerous occasions, I feel comfortable with how things turned out. Good to know there is an on-screen option and will keep in mind for the future. Thanks for the info. Quote Link to post Share on other sites
kingoftypos Posted April 28, 2015 Report Share Posted April 28, 2015 Just on the page before this, is where the official thread is located for the bypass. Here it is... http://avic411.com/index.php?/topic/38589-official-avic-nex-bypass-avic-units-only/ KOT Quote Link to post Share on other sites
talkin73 Posted April 29, 2015 Author Report Share Posted April 29, 2015 Just on the page before this, is where the official thread is located for the bypass. Here it is... http://avic411.com/index.php?/topic/38589-official-avic-nex-bypass-avic-units-only/ KOT Thanks! Quote Link to post Share on other sites
