jonyb Posted September 12, 2007 Report Share Posted September 12, 2007 I've got the D3 and the BT module to go with it, and I'm using a Verizon Wireless Blackberry 8703e. The phone was crushed the other day by an 85lb. dumbell so I had to get a new one. The previous phone would automatically connect to the bluetooth when the head unit powered up or I got back in it while running. The new phone will not do this. I've been through everything as far as checking the settings from the "menu" button while on the BT function, I've swapped BB's and tried others with no luck, and I've changed all the settings in my phone and nothing seems to work. You have to manually connect the phone to the head unit everytime, and on a BB that's about 6 button presses. Not even worth it for a short trip. Once the phone is connected, everything works properly, it's just that it won't automatically connect. Any suggestions? Quote Link to post Share on other sites
myvekdrifters Posted September 12, 2007 Report Share Posted September 12, 2007 did you still have the old phone registered in the 1st slot? Cuz the D3 seem to autoconnect only to the 1st slot. Also, check to see if auto connect is set to on. Quote Link to post Share on other sites
jonyb Posted September 12, 2007 Author Report Share Posted September 12, 2007 did you still have the old phone registered in the 1st slot? Cuz the D3 seem to autoconnect only to the 1st slot. Also, check to see if auto connect is set to on. Thanks for the reply. I've deleted the first phone, and the auto connect is set to on. Now that I think of it, I can't remember if the new phone is added on that first slot. How can I add it? The head unit and phone are paired and work, but I'm not sure if it's added in that slot... Quote Link to post Share on other sites
knight20 Posted September 12, 2007 Report Share Posted September 12, 2007 You can try and reset the BT unit. That should erase all the current information and previous pairings. This will also delete contacts you pushed to the unit, so up to you. Quote Link to post Share on other sites
jonyb Posted September 12, 2007 Author Report Share Posted September 12, 2007 Thanks, I'll try that. I lost the contacts stored in the unit a couple weeks ago because I had to have the D3 replaced. Quote Link to post Share on other sites
VBLUE42 Posted September 12, 2007 Report Share Posted September 12, 2007 did you still have the old phone registered in the 1st slot? Cuz the D3 seem to autoconnect only to the 1st slot. Also, check to see if auto connect is set to on. myvekdrifters there are plenty of other good avatars out there. Quote Link to post Share on other sites
myvekdrifters Posted September 13, 2007 Report Share Posted September 13, 2007 sorry buddy...i can't find a descent avatar to represent myself using a d3 but a d3 image. the gallery doesn't have it...hope you don't mind...if you do i'll repalce it and put up my Emperor logo...Mitsubishi Lancer Evo Emperor...one of the best club sport for Lancer Evolution. Quote Link to post Share on other sites
VBLUE42 Posted September 14, 2007 Report Share Posted September 14, 2007 Just kidding Quote Link to post Share on other sites
necro Posted September 14, 2007 Report Share Posted September 14, 2007 On your BB, be sure you set the Pioneer BT unit to trusted and auto. Quote Link to post Share on other sites
jonyb Posted September 14, 2007 Author Report Share Posted September 14, 2007 I did that... I also tried the "Device Name" to be 0000 so it would skip a step and that didn't work. Under "Device Properties" on the phone I have the following: Device Name: 0000 Trusted: Yes Encryption: Enabled Echo Control: Automatic Under "Options" I have: Device name: 0000 Discoverable: Yes Allow outgoing calls: Always Address Book Transfer: All entries (Like it matters because Verizon screws us up on that) Quote Link to post Share on other sites
myvekdrifters Posted September 15, 2007 Report Share Posted September 15, 2007 You said you have already made connection. From what I'm understanding you can't seem to get it to autoconnect. Were you able to register the phone yet? I mean, on your D3 AV Menu, BT phone, tap Function, Phone Register, and make sure the first slot there is your phone and not anyone else. If not, delete it, and make connection to your current phone, if not yet connected. And hold that 1st slot until your phone displays in that slot. If not, try resetting in one more time on your Blutooth first, then if not, your D3 and Blutooth. And try again. Otherwise, your phone is not searching. Try resetting your phone as a last resort. otherwise, i'm stuck like you. Quote Link to post Share on other sites
myvekdrifters Posted September 15, 2007 Report Share Posted September 15, 2007 oops, i meant your phone is not sending signal to be discoverable. Quote Link to post Share on other sites
jonyb Posted September 15, 2007 Author Report Share Posted September 15, 2007 I mean, on your D3 AV Menu, BT phone, tap Function, Phone Register, and make sure the first slot there is your phone and not anyone else. If not, delete it, and make connection to your current phone, if not yet connected. And hold that 1st slot until your phone displays in that slot. I did that yesterday and what I hadn't been doing was adding it to the list. Works just fine now..... Thanks for all the help fellas! Quote Link to post Share on other sites
