dvboy Posted February 25, 2016 Report Share Posted February 25, 2016 I have had my hu for about 3 months,every time I go to receive a call the connection fails.I have an app on my iphone 6 that records the calls,and here is the strange part,the callers voice speeds up really fast on the recording sounding like mickey mouse,although on the live call I can't hear them??One thing I discovered is when I answer my NEX has a little window saying "private ON".....when I turn it to private off everything seems to function as normal.The next call it defaults back to private ON,any way to default it to "private OFF"???? Quote Link to post Share on other sites
Multitask Posted February 25, 2016 Report Share Posted February 25, 2016 I don't remember a setting for that, but what I would do is see if answering it by the phone changes that. You might be touching the Green answer and then accidentally keeping it there and the Private On/Off is in about the same place (going from memory) Private On is basically a "Mute" of the sound As far as the sped up voicemail, I'm guessing it's the phone.... try reseting the BT on both, and re setup... that also might fix both... Quote Link to post Share on other sites
dvboy Posted February 27, 2016 Author Report Share Posted February 27, 2016 Thanks for the reply,my solution ended up being deleting the call recording software.I assume it couldn't record over speaker,so by default it kept switching over to private mode. Quote Link to post Share on other sites
Esfour Posted February 29, 2016 Report Share Posted February 29, 2016 Does the NEX unit require additional modules for Bluetooth like the other Z series did? Quote Link to post Share on other sites
