nuttzzy34 Posted September 18, 2007 Report Share Posted September 18, 2007 ok my z-1 crapped out, it had a internal short somewhere and fried in this process. however, also in this process the radio somehow sent a curent threw the car and not the car computer is affected car still runs and everyhting but it says i have an open door even when there all shut and the trip meter was erased does anyone know a manual bypass to reset the computer?? i know this isnt a mazda post but hey might as well ask. the real question is i bought a z-2 can i use the same gps and stuff like that? im ganna replace the harness though and also the 2 wire bypass wont work on it hu?? any input on my situation would help a bunch thanks in advance Quote Link to post Share on other sites
brandon Posted September 18, 2007 Report Share Posted September 18, 2007 ok my z-1 crapped out, it had a internal short somewhere and fried in this process. however, also in this process the radio somehow sent a curent threw the car and not the car computer is affected car still runs and everyhting but it says i have an open door even when there all shut and the trip meter was erased does anyone know a manual bypass to reset the computer?? i know this isnt a mazda post but hey might as well ask. the real question is i bought a z-2 can i use the same gps and stuff like that? im ganna replace the harness though and also the 2 wire bypass wont work on it hu?? any input on my situation would help a bunch thanks in advance Pretty easy to reset a car ecu. Just disconnect the battery for a little while, then reconnect. Ecu reset. As for your other problems, good luck. Quote Link to post Share on other sites
MPS Posted September 18, 2007 Report Share Posted September 18, 2007 this will help you with ur Mazda problems http://www.mazda3forums.com/ Quote Link to post Share on other sites
