WildBill Posted December 11, 2018 Report Share Posted December 11, 2018 Hi AVICers - been reading the forum for a while, but this is my first post. I've got an AVH-W4400NEX that's been installed for a couple of months. I had a hard time getting a 256GB SD card to be visible in the unit -- I'd hit the eject button, push the SD Card icon on the screen, and then slot the card in, but it would just sit there at that point. No matter what I tried, formatting with FAT32 or NTFS -- I couldn't get the card to be seen by the unit. I fiddled with this for a while, and on the last run through, I failed to get the card latched all the way in the slot. I hit the eject button to order the faceplate to swing back up - and it did, but when I tried to get the card back out, the card kept the faceplate from opening all the way... it was stuck partially open. I was able to get my pocketknife between the partially open faceplate and the body of the unit, and I got the card pushed back into the slot all the way, and then I got the faceplate closed. But now... the faceplate won't open back up again when I hit the eject button. The unit appears to work just fine otherwise -- CarPlay, XM, AM/FM, Bluetooth all work. I've tried both a pin-reset on the front panel, and a factory reset from the settings menu, but neither one has enabled the faceplate to open up again. Is there another way to get this thing to work? I called Pioneer and they want me to remove the unit from the dash and send it in, with an ETA repair time of two weeks. I'm not against trying a diagnostic tool via USB or anything, but I don't know if there are any next steps I can take. I'm running firmware 1.01 if it matters. Also, I'm not in the slack group - but I'd be happy to chat about this there if that's easier. I appreciate the help this community's given -- this board is the main reason I picked a Pioneer over other brands. Thanks in advance! Quote Link to post Share on other sites
asd255 Posted December 12, 2018 Report Share Posted December 12, 2018 This is a hardware problem. Only in the service center will help you. You need to set the gears correctly. Do not try to do it yourself. Quote Link to post Share on other sites
WildBill Posted December 12, 2018 Author Report Share Posted December 12, 2018 Thanks, that's a bummer though... was hoping this community would have an answer for this. Surprised there's not a dev-mode "reset front panel position" option, or anything like that. The unit works great right now, and I really don't want to rip it out from the dash, send it in, and be unable to drive my car for a couple of weeks... Quote Link to post Share on other sites
Zakykan Posted July 16, 2023 Report Share Posted July 16, 2023 On 12/11/2018 at 8:02 PM, asd255 said: This is a hardware problem. Only in the service center will help you. You need to set the gears correctly. Do not try to do it yourself. Im facing the same issue. i tried to set the set the gear at many position. But its hard to set the exact position. but it looks that the 2 gears has to be sync in an exact position, otherwise it will send a different function to the head unit. is there any documentation or diy to set the gear? thanks Quote Link to post Share on other sites
asd255 Posted July 22, 2023 Report Share Posted July 22, 2023 Quote Link to post Share on other sites
