ekidd Posted October 25, 2007 Report Share Posted October 25, 2007 I just did the avic n1 bypass on my 350z and for some odd reason my parking lights wont turn on anymore. I went and checked all the wiring/connections as well as all my fuses and everything was fine. I need help asap because now i cant drive at night! Anyone know what the problem could be???? Quote Link to post Share on other sites
tillithz Posted October 25, 2007 Report Share Posted October 25, 2007 well, remove the bypass and see if lights still dont work. likely ... hopefully you have a fuse blown somewhere you may not have seen. OR depending on how you checked the fuses, you should recheck them with a tool as opposed to just your eyes. also, check your dimmer knob/switch to make sure its not just turned down Quote Link to post Share on other sites
ekidd Posted October 25, 2007 Author Report Share Posted October 25, 2007 I disconnected the bypass and the lights still dont work..ill go ahead and use something else to check the fuses again. Anymore ideas anyone on what it would be?? Quote Link to post Share on other sites
