jbsengineer Posted November 9, 2007 Report Share Posted November 9, 2007 Installed the bluetooth adapter last night. This did require me to take the D3 out of the dash etc. Now when I checked the connection status I'm getting a "Excessive Vibration" reading. Is this because I tipped the D3 all around when I removed it out of the dash and reinstalled it etc. The 3D calibration did not lose it's settings. It's mounted the exact same way before I took it out. Nothing has changed. Would resetting the 3D calibration memory fix this? Thanks. Quote Link to post Share on other sites
MisFit Posted November 9, 2007 Report Share Posted November 9, 2007 moving it wouldnt cause that unless you didnt secure it all the way when you reinstalled it. try sitting still a minute with the info screen on and see if it goes away then start moving and see when it comes back. it usually clears itself up as long as its mounted properly. what kind of car is it? Quote Link to post Share on other sites
jbsengineer Posted November 9, 2007 Author Report Share Posted November 9, 2007 2007 Trailblazer. I haven't noticed this at all in the past week or so. Even did a 500 mile trip and nothing. Quote Link to post Share on other sites
nyskinsfan Posted November 9, 2007 Report Share Posted November 9, 2007 You could try resetting the 3d calibration. I get the same issue when I change something with the Z2 in my TB. Usually doesn't take too long to go back to OK. Quote Link to post Share on other sites
jbsengineer Posted November 9, 2007 Author Report Share Posted November 9, 2007 You could try resetting the 3d calibration. I get the same issue when I change something with the Z2 in my TB. Usually doesn't take too long to go back to OK. I will give it some time. But just in case how can you reset 3D calibration settings? Quote Link to post Share on other sites
jzsax1 Posted November 9, 2007 Report Share Posted November 9, 2007 i reset the calibration on my unit and blank all the values and the problem went away! Quote Link to post Share on other sites
