szalkerous Posted November 11, 2007 Report Share Posted November 11, 2007 Hi... When I try to set my home location on my AVIC-D1, by clicking "Save", I get a box that pops up reading "Saving Information. Please do not shutdown the system" and it sits there. I can use my A/V sources, but if I go back to the navigation, that screen is still there. I waite about 10 minutes, and finally gave up and powered off. If I turn it back on, it's back to normal. Anyone have any advice? Navigation seems to work fine otherwise. My NavTraffic is also working fine. Quote Link to post Share on other sites
calvin13 Posted November 12, 2007 Report Share Posted November 12, 2007 The data cable is causing the issue. If you disconnect the cable it will work correctly. But, your NAVTraffic will not work. This is XM fuccking over the consumer again. Quote Link to post Share on other sites
