Mo-D Posted December 19, 2007 Report Share Posted December 19, 2007 I bought a new car for my Z1 (LOL) and I figured while I was installing it I would wire up the 2-wire bypass. I wired it through a SPDT switch so I could have it in bypass mode, or normal parking brake mode. Anyway, I read that you are supposed to insert the update CD and press "MAP" to do the update. But, it's not working. Am I supposed to put the CD in and press MAP right away, or wait until after it checks the disc and says "CD ROM inserted"? I've tried it both ways, so I guess I burned the file wrong??? I unzipped the file, and then using ISO Recorder I did "Copy image to CD" on the AvicBluetoothFix.iso file. Any ideas??? Quote Link to post Share on other sites
whtcrxghst Posted December 19, 2007 Report Share Posted December 19, 2007 Just double click the iso file. It should automatically open a burning program for you Quote Link to post Share on other sites
Mo-D Posted December 21, 2007 Author Report Share Posted December 21, 2007 It does, but it opens the same program, the Iso Recorder. If I were to view the CD in windows explorer, what should it look like? in the root I have some folders and some files. I don't have Nero or anything else on this computer. Quote Link to post Share on other sites
whtcrxghst Posted December 21, 2007 Report Share Posted December 21, 2007 I use Active ISO burner. It worked the first time Quote Link to post Share on other sites
Mo-D Posted December 23, 2007 Author Report Share Posted December 23, 2007 Thanks for the tip. I downloaded that program and it worked. I guess the ISO recorder program burned in a different format or something. The file structure on the CD looked the same. Oh well, it works now. Quote Link to post Share on other sites
