muddyoval Posted December 20, 2007 Report Share Posted December 20, 2007 Everyone said it couldn't be done- it's not hard, you just have to be resourceful. "Dealer installed" Avic88 with touchscreen was a nightmare- they farmed it out to a hack shop- they stuck the touch screen right to the dash fascia with tape and screws. Wiring was hacked up- bad installation in every way. No shop would attempt it, most claimed "no way" to do it. The key- use a Lincoln LS dash plate and Ford Motorsport dash paint. The pics make the color look a little off, but in person it matches the dash perfectly. I used an adapter to keep the stock subs (use a 5V converter for the turn-on lead). Installed all Polk speakers while I was in there too and a Boyo reverse camera. The t-bird doesn't have a dash dimmer circuit, so tap it at the switch too. Lousy dealer installation. Lincoln LS plate Only thing that required drilling- side mounts. I used stainless cap screws. Test fit- had to use a Dremel to adapt the LS plate. LOTS of plastic removed. Painted with Ford dashboard paint. Installed and working- bypassed too. The flash makes it look as if there's a gap at the top, but there isn't once I put the felt anti-queak stuff between the top of the fascia plate and the top vent assembly. The paint is a little more reflective than the dash, but it is an exact match when not looking at it with a flash strobe. Done deal- as it should have been... I made a T-bird background for it and most people now think it is a factory unit. I used a SWIX adapter to retain ALL the steering wheel remote functions. The sound is amazing- Polk Db's all around, Sirius radio, factory amplified subs. If anyone needs one installed in VT- I think I have it 'down' now that I've done this one. Thanks a LOT to this board for the info to do this project. I know that like most others, we lurk and learn, but without this forum it wouldn't have been possible. Thanks! Quote Link to post Share on other sites
32valvefox Posted December 20, 2007 Report Share Posted December 20, 2007 very niiiice... when there is a will... there is a way Quote Link to post Share on other sites
