GEX-P7000TV tuner
By GnatGoSplat · Aug 09, 2006in General💬 36 posts👁️ 14,432 views
Page 2 of 2
Posted Feb 12, 2007 · 12:45 UTC#26
If you don't already have a tuner, I wouldn't get it.
February 17, 2009, all analog over the air broadcasts will be terminated. This isn't that far away.
I've saved my money, and I'm glad. Sirius is coming out with a TV tuner 1Q 2007 (which means soon).
http://www.orbitcast.com/archives/ces-s ... at-tv.html
Back on topic, I wonder when Pioneer will release a digital or high definition model, that will be required to receive broadcasts after February 17, 2009.
Posted Feb 12, 2007 · 13:58 UTC#27
2 years, huh?
Posted Feb 12, 2007 · 15:04 UTC#28
IMO, 2yrs is a long time away to be worrying about whether or not to buy something electronic today.
I typically get the upgrade bug once a year, sometimes even after as little as 6-months.
Posted Sep 11, 2007 · 18:47 UTC#29
How do you do this: Pin 12 to + 12v, Pin 1 = Video Ground, and
Pin 2 = Composite Input
So the only mod that needs to be done is to the AV-Bus?
How do you connect the pins together?
Posted Dec 13, 2007 · 03:34 UTC#30
HEY GUYS I'M NEW TO THIS FORUM. I HAVE AN AVIC-D2 AND I PURCHASED A GEX-P7000TV THINKING THAT IT WOULD JUST CONNECT TO MY D2. I WAS ABOUT TO RESELL THE TUNER UNTIL SOMEONE TOLD ME ABOUT THIS FORUM. SO AFTER LOOKING I PURCHASED A AV-BUS CABLE AND BEFORE I CUT THE CABLE I WAS WONDERING IF SOMEONE COULD TELL ME IF THE WIRES INSIDE OF THE CABLE ARE COLORED SO I WILL KNOW WHICH ONE TO CONNECT TO THE RCA PLUG THAT IM GOING TO ATTACH TO THE END OF THEM, AND WHICH ONE I SHOULD SEND TO 12v, ALSO IN NEED TO KNOW WHICH PINS ARE 12 AND 20 IN THE GREEN CONNECTOR ON THE GEX-P7000TV SINCE THEY SHOULD BE ATTACHED TOGETHER. I SEE THE ONE POSTING SHOWING THE PIN COUNT FOR THE AV-BUS, BUT Gnatgosplat SAID THAT YOU HAVE TO CUT THE CABLE SO I WAS WONDERING IF THE WIRES INSIDE WERE COLOR CODED. DO ANYONE HAVE ANY PICS SHOWING THE PIN COUNT FOR THE GREEN CONNECTOR FOR THE GEX-P7000TV THANK YOU ALL IN ADVANCE
Posted Dec 27, 2007 · 02:34 UTC#31
before you cut the cables on the 7000 would you consider a trade for a newer tuner that has the avbus and ip in and out
Posted Jan 13, 2008 · 13:47 UTC#32
does any body know if the 7000tv will convert all osd display to the rca video out? and does it have a standard rca video out for the front out also want to hook it up to a avm-p8000 tuner for a bigger main monitor
Posted Jan 17, 2008 · 23:35 UTC#33
If I recall correctly, I think you can switch the OSD on and off.
Did you already trade for a 7000TV?
Posted Feb 06, 2008 · 02:46 UTC#34
bought a 7000tv sold the d1 trying to put bigger screen on my avm 8000tuner cant find a rgb conversion to display osd wen in video mode for front source
Posted Feb 06, 2008 · 08:26 UTC#35
2 years is a long time. Most people probably would have placed their D3 on ebay by then and had bought a D4 or Z3.
Posted Feb 06, 2008 · 08:58 UTC#36
That's only 1 year, dude. 2/08 - 2/09. Maf skillz, yo.
Page 2 of 2
