z2 to replace shaker 500 in 06 mustang?
By executioner · Jun 06, 2008in General💬 55 posts👁️ 13,348 views
Page 1 of 3
Posted Jun 06, 2008 · 09:02 UTC#1
I have a 2006 mustang with the shaker 500 system. Will the avic z2 work as a replacement? How much of the factory stuff will need to be replaced? Anyone done this in a mustang? Thanks
Posted Jun 06, 2008 · 12:36 UTC#2
i just bought my fiance' an 06 stang and its got the shaker. all you need is an OEM radio wiring harness, an avic, and a trim kit. also the tools and knowledge to swap units :wink:
Posted Jun 06, 2008 · 23:12 UTC#3
Cool! Did you put a z2 in it? How does it work woth the shaker amps and speakers? Did you do anything else to it?
Posted Jun 06, 2008 · 23:17 UTC#4
o i didnt put anything into it lol i just know electronics. im not too familiar with shaker tho, as far as it having factory amps and such. my rx8 has bose so i hadda buy bose adaptors. so if the car does have amps then you need an adaptor of some sort and youd hafta use the system remote wire to power the stock amp. lemme know if you find anything out, and ill search too, cuz i was gonna get an avic for her
Posted Jun 08, 2008 · 23:31 UTC#6
Yea, I have gone the crutchfield route many times I just had my worries as to whether this was gonna work with the shaker sub and amps in the doors. Looks like it will. Guess I will take the plunge since I cant seem to find anyone who has actually done this to thier vehicle. Thanks
Posted Jun 09, 2008 · 00:21 UTC#7
trust me itll work. those plugs include the shaker amp.
Posted Jun 12, 2008 · 03:40 UTC#8
I put the Avic Z3 into my 07 Mustang with a Shaker 1000 sub woofer. You will want to pick up a $2 part at radio shack otherwise you will have an annoying pop in your subs every time you power up the head unit. The subs in a Mustang only need 5V to power up. The Avic's send out 12V to the relay's that turn on the amps. The part you want is a 5V fixed voltage regulator. Radio Shack catalog number 276-1770. http://www.radioshack.com/product/index ... 2062599&cp
The only other modification is the headlamp dimmer wire. The factory harness does not supply this. You will want to run a wire over to the back side of your headlamp switch. Locate the orangish/tanish wire with a white stripe and tap into it there.
EDIT: The only difference between the Shaker 500 and 1000 is the number of amps. The 500 has the subs in the front of the doors. The 1000 has these as well in addition to the large sub box in the trunk.
Posted Jun 12, 2008 · 12:14 UTC#9
thanks for the info :D sorry for a the noobish question, but where does that regulator get wired into???
Posted Jun 12, 2008 · 14:25 UTC#10
No need to apologize. Having questions up front is better than during the installation. I am assuming you are or have purchased a wiring harness kit. The harness for the subs has 4 wires coming off of it. Depending on the kit, two are blue with a white strip and the other two are actually red and white RCA jacks. Don't think of these as left and right. You will want to solder some leads off of the regulator so you easily work with it. The two blue/white wires connect to one side of the regulator, the middle post on the regulator is ground, which gets grounded. The other side of the regulator goes to the amp on wire coming from the head unit. When the HU sends out a 12V on signal, the regulator reduces that to 5V and then continues on to the relays that power the amps/subs. The RCA jacks on the harness go to the subwoofer RCA leads from the HU. Red to Red, White to White.
Lastly, if you plan to hook up the speed pulse or vehicle speed sensor cable (VSS,) It is possible to come through the firewall behind the glove box where the factory antenna comes through. Removal of the battery and battery tray is needed. And with a buddy, one to push through and one to grab it, the wire can be fed. This is the way I ran it instead of going through the clutch cable area on the drivers side.
I read these write-ups which helped me answer a few questions.
http://www.mustangforums.com/m_3581800/tm.htm
http://www.mustangforums.com/m_4489289/tm.htm
http://forums.stangnet.com/showthread.php?t=736028
http://forums.stangnet.com/showthread.php?t=749121
Posted Jun 12, 2008 · 14:33 UTC#11
Thanks for the info!! actually i havent bought anything, my fiance's birthday is comin up and she just picked up an 06 stang so i wanted to hook her up with an avic. i did however find the wiring harness needed off crutchfield, with the shaker amp adaptor, & ill deff order one of those regulators. Thanks again!!
Posted Jun 12, 2008 · 16:46 UTC#12
Not sure how much your time is worth, but you might want to look at a PAC c2r-frd1 wiring harness. List is like $140, can be found for around $70. Well worth it if you don't want to do a lot of wiring in cramped places.
It is a canbus adapter wiring harness.
http://www.pac-audio.com/products/produ ... ce-a-Radio
About half way down the page.
• R.A.P. (Retained Accessory Power) +12v output.
• VSS output.
• Illumination output.
• Parking brake output.
• Reverse trigger output.
• Digital amp turn-on.
• Discrete 5v amp turn-on
All right in the harness.
Much easier install, and no tapping/splicing of any factory wires.
Just my $0.02.
Posted Jun 12, 2008 · 16:54 UTC#13
Very nice. Wish I had known about this about a month ago.
Posted Jun 12, 2008 · 17:28 UTC#14
• VSS output.
Just my $0.02.
THANKS FOR THE TIP!! so thats the radio wiring harness that i would need and it also works for shaker 500 and 1000??
Posted Jun 12, 2008 · 17:41 UTC#15
Yep. No thanks needed. I was tickled s***less when I came across it. Probably saved myself a good 3-4 hours of sweat.
Compatible Vehicles:
2005-2007 Five Hundred, Freestyle, Montego
2005-2008 Mustang (Shaker 500 and 1000 included)
2006-2008 Explorer, Fusion, Milan, Zephyr, Mountaineer
2007-2008 MKX, MKZ, Navigator, Sport Trac, Edge, Expedition
2008 Escape, F-250, F-350, F-450, Taurus (X), Marnier, Sable
2008 F250/350/450 with XL trim package are NOT compatible!
Latest Revision: 1.1.2
Instruction manual...
http://www.pac-audio.com/instructions/c2r-frd1.pdf
It actually has a few extra things in it as well. No need for steering wheel control wire. There is also no factory rear seat entertainment wiring in a 'stang, but if it has the factory line in wiring, that should wire up as well. Can't verify that, mine is an '05 and factory line input didn't exist.
Posted Jun 12, 2008 · 18:42 UTC#16
I am a dealer expeditor that specializes in Ford. The PAC piece is definitely the easiest way to get Z2 installed. As far as using the harness referenced from crutchfield it is a METRA 70-5521. The radio shack regulator can be used, but there is a much easier way. Put between a 3.5k up to 5k resistor (I usually use a 3.9k or 4.7k from Radio Shack 1/4 or 1/2 watt doesn't matter either works fine) in line with the blue/white amp turn on wire. Meaning attach one end of the resistor to the wire coming from the radio harness and the other end to the adapter harness. This will eliminate the amp turn on pop. And for the RCA's you will only need the white one and the blue/white turn on wire that is in the same row. The red RCA drives the trunk subwoofers with the shaker 1000 system. I use an RCA-Y adapter with 1 female end and two male ends to connect the single white RCA to the radios dual subwoofer outputs.
For the speed signal it is dark blue with yellow at the PCM top connector pin 3. PCM is located under the hood passenger side front of engine compartment. I run the wire through the firewall grommet in passenger footwell area. Turn the wheels all the way to the right and you can pull the inner fender well plastic out easily enough to reach in and grab the wire put through the grommet. Then feed it under the battery tray to inside of engine compartment with a coat hanger or something simular. From there run it forward to the PCM, connect and cover with split loom.
The reverse wire is White with Yellow in harness under passengers side door sill plate coming from the fuse box (called the smart junction box).
Illumination is Black with Pink in the harness going through firewall in passenger footwell area. This wire powers front parking light.
Posted Jun 12, 2008 · 19:09 UTC#17
I am a dealer expeditor that specializes in Ford. The PAC piece is definitely the easiest way to get Z2 installed... regulator...
resistor... speed signal ... pull the inner fender well plastic out ... coat hanger ... firewall ...
:shock:
Your instructions are exactly the reason I spent the extra $ for the PAC. I just don't have the patience to do much of that stuff anymore. Sure didn't want to crawl into the tire well to install a radio... :roll: Running wires is one thing, keeping it all neat is a different story. I also have a deep aversion to doing anything to factory wiring. Hats off to you guys that do this stuff for a living.
Glad to hear that you agree on the PAC harness. Nice write-up, though. Very informative.
Posted Jun 12, 2008 · 19:20 UTC#18
:shock:
AGREED. not about the aversion, i meant the informative part. hands down the most useful information ive gotten from this forum so far. and its only tapping into the factory wires if you wanna do the reverse wire or the vss. everything else is plug and play, correct sterodan??
Posted Jun 16, 2008 · 05:05 UTC#19
Well I got the z2, bluetooth, XM and camera in today and so far everything works great. I have to tuck the wires and put all the panels back on tomorrow. I have the AVIC n2 in my truck and it doesnt start to compare to the z2. All I can say is WOW, I love this thing!
100_2404.jpg[/img]
Posted Jun 22, 2008 · 19:49 UTC#20
Posted Jun 23, 2008 · 14:42 UTC#21
Hey guys
I actually just bought the z2 today and I'm gonna be putting it in my '06 Mustang with the Shaker 500. I plan on buying that PAC wiring harness to save myself some trouble when installing it.
Is there anything that I'll need besides a mounting kit when installing z2? I'd like to just do it myself instead of having Circuit City do it...
Posted Jun 23, 2008 · 14:46 UTC#22
Hey guys
u need a wiring harness
a double din dash kit or the 06 mustang
the oem wiring harness kit for an o6 mustang
a 06 mustang shaker adaptor
a 1000ohm resistor or a 5v regulator from radioshack
much patience for those pain in the ass temperature plugs :lol:
Posted Jun 23, 2008 · 14:47 UTC#23
Solder, Soldering Iron, Heat shrink tubing.
Electrical tape and zip ties are also very handy to have.
PAC harness isn't exactly cheap for a wiring harness, but I sure am glad I had it. Everything just "worked." Truly a painless install.
Granted, that was for an f-series, but it should be just as painless on a z.
Posted Jun 23, 2008 · 14:50 UTC#24
He has PAC harness. It takes care of all of that for you.
mroaches, you bought the c2r-frd1 oem stereo replacement harness, right?
Posted Jun 23, 2008 · 14:58 UTC#25
I got my Z2 from crutchfield, it came with the radio, blue tooth adapter, ipod interface, camera, disassembly and reassembly instructions, all wiring harnesses and adapters, install instructions etc for $1399 and was here in 2 days. Everything i needed was in the box except the resistor mod and the xm box. Instructions were very easy. Just do the wiring harness inside in the air conditioning before you go out to the car. Take your time and read the book and posts it is not hard at all and sure beats paying bb 300-400 to do it.
Well they went up 100 from when I got mine 2 weeks ago :shock:
http://www.crutchfield.com/App/Product/ ... Z2X&tp=526
Page 1 of 3
